Rear Disk Conversion
Old Jul 21, 2002 | 07:08 PM
  #51
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
Originally posted by incublinkus
I heard the AEM kits was good but it squeaked alot. Is the AEM conversion kit like a GSR/Si swap only with AEM rotors and Pads? or is it something custom made by AEM and different completely?
i think it fits the stock LCAs and rotor hubs.
AEM gives you rotors, cals, and pads, and i think some tubing and mounting hardware.
Old Jul 21, 2002 | 08:08 PM
  #52
incublinkus's Avatar
incublinkus
JDM Fan Boy
thanks man.
not that it would be cost effective, but you wouldn't happen to know if you could install this kit, but get better rotors like Brembo and such? thanks
Old Jul 21, 2002 | 08:12 PM
  #53
Fujiwara Takumi
It's my first day.
thanks man.
not that it would be cost effective, but you wouldn't happen to know if you could install this kits, but get better rotors like Brembo and such? thanks
thats where you would get those teggy lower drops and hubs...aem is the only company on the block that has rotor retro fits for a civic.
Old Jul 21, 2002 | 08:53 PM
  #54
skubb's Avatar
skubb
not that TLC sh!t either
Originally posted by H-A Stud
If you don't know what the trailing arm is...I wouldn't recomend doing this project alone h:
:sqfawk:
I knew which part it was, just wanna be sure so I don't pic up the wrong part somehow.
don't plan on doing this mod for a while anyway. sounds like a bish.
Old Jul 21, 2002 | 08:56 PM
  #55
Fujiwara Takumi
It's my first day.
why?
ive had all these parts damn-near off for my suspension anyways.
Old Jul 23, 2002 | 10:01 AM
  #56
tokyoracer's Avatar
tokyoracer
got JDM milk???
does anyone have a step by step instructions on how to install it? i found a 96 GSR disc brake swap for $350... so i need to know how to go about in installing it. and should i modify my master brake cylinder with the GSR one?
Old Jul 23, 2002 | 10:27 AM
  #57
white lightnin's Avatar
white lightnin
Two pages. Damn its not that tough. The parts look the same from both cars. The teg ones are just bigger obviously. My advice is to take apart your civic before you get the parts if you can afford to. I just went at it and kinda figured it out. If you want to do the bare minimum just leave all the control arms (front, rear, lower, upper) as well as the rear compensator arm. and replace the assemblies which attach to these arms. Should be the knucle up front including rotor and caliper. And a much larger piece in the back. DOnt know exact name. Just a large metal sort of frame including same pieces i described for the front as well as the ebrake cables.
Hondas arent complicated. If you arent a retard you should kinda be able to mess with stuff like this and figure it out.
I would recomend swapping out for entire gsr suspension (LS is the same except for rear bar i believe) and at the same time reaplacing all the bushings, as well as getting new pads and rotors.
Why dont we close this thread and make it a sticky...or just make it a sticky. Im sure that all the info anyone needs is in it by now.
Old Jul 23, 2002 | 02:24 PM
  #58
ISP James's Avatar
ISP James
DAMIMRED
it is the kit made for ex drum - disk conversion and it lists around 1100 bucks.
Old Jul 23, 2002 | 02:37 PM
  #59
incublinkus
JDM Fan Boy
No **** jackass. I know that. Thats not what I asked
Old Jul 23, 2002 | 02:40 PM
  #60
Fujiwara Takumi
It's my first day.
i actually found it for $679. I think i posted a link in this thread.
