CEL 54, check engine light
Originally posted by SpeedRacerEX-R
That sensor isn't in the coil. It's a magnetic pick up IN the distributor.
the CKF is down by the crank.
The signal from one of the sensors in teh distributor and the signal from teh CKF is compared and if they dont match close enough you trip a code....anyway the CKF can be found on the drivers side of the engine, look for a wrapped bundle of 3 wires on the back side of the engine on the drivers side, it will be going down the side of the timing belt cover...you will probably need to pick up a haynes, chiltons or helm manual to be able to test it and know what results you need to see...unless it is just unplugged that is.
Ahhhhh, that's right. And CKP is in the dist. Damned OBDII crap. Either way, it's sensor replacement time.
yeah...heheh the CKP measure CAM angle lol and then the signal should match up right ot the CKF signal!! i hate trying to remember them all...
Nelson
Other Honda & Acura News
Jul 25, 2008 03:10 AM
greengsr2k
3
Aug 15, 2004 08:28 PM
99IntegraGS
May 3, 2004 04:56 AM
