CEL 54, check engine light
Old Jul 10, 2002 | 04:17 AM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
Default CEL 54, check engine light
whats the code mean, wheres the database, i cant seem to find it?
Old Jul 10, 2002 | 06:03 AM
white lightnin's Avatar
white lightnin
C Speed has a list of codes. Check it out.
http://www.c-speedracing.com/
Old Jul 10, 2002 | 06:07 AM
Fujiwara Takumi
It's my first day.
ok i give, whats the cure:
54 96-98 Civic
97-98 CRV
94+ Integra CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
i mean, im throwing a 54, but im a 1999 hatch, and im not technically on that list. any idea? where is this sensor so i can check if its loose? my car is in limp mode right now so its running for ish. help would be appreciated :-\
*edit* - i see the list only goes up to 1998, it jsut hasnt been updated recently. gimme ideas
Old Jul 10, 2002 | 07:28 AM
Fujiwara Takumi
It's my first day.
ok, im reading some websites that claim this can be an issue of misfires deviating more than 2% cylinder to cylinder, but typically that causes codes of the misfire issue.
could really use some help. :-\
Old Jul 10, 2002 | 09:10 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
wish i could help ya man....havent had to deal with codes yet. (knock on wood)
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
That sensor plays a roll in timing advance. Older cars used to be on a vacuum advance. As the revs climb, the timing needs to advance. Anyways, that sensor is usually found in the dist. or right by the crank pulley.
Old Jul 10, 2002 | 09:11 AM
Fujiwara Takumi
It's my first day.
my first one was some bs about vapor recovery, etc, it ended up being a missing fuel cap...so the codes can be misleading if you're not in the industry.
you proly dont drive the piss outta your car either though, im pretty mean to her.
Old Jul 10, 2002 | 09:12 AM
Fujiwara Takumi
It's my first day.
yay, a mod,
ok, does it imply that the sensor is off, or does it imply a need to advance my timing? should i check my timing?
(i think its time to order that there helms)
Old Jul 10, 2002 | 09:25 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
i drive my car pretty hard(drag racing, and also drive like an ass daily) but might also be the climate etc?
Old Jul 10, 2002 | 09:27 AM
Fujiwara Takumi
It's my first day.
well, im at 45,000, due for an oil change, and i have no record of a tuneup.
