The BEAST Build. My Quest for 10's
Starting to wonder if my trans is what caused my main's to fail, or possibly whats causing my alternator belts to fly.
maybe under high load situations and high rev, it creates a nasty amount of movements with my main shaft in the trans which is sitting in the center of the flywheel & directly connected to my crank... (just thoughts that are turning in my head)
Come to think about it that can be your problem. I have talked to a tuner, and he was talking about how many oil pumps and main bearings that get blown apart from using a CTR pulley, that they lack the little bit balancers that the stock pulley have (the rubber part i showed you at jarfro's place). And it being so small it cant compensate for the large amount of vibration having a bad input shaft bearing will cause unwanted vibration in the motor, which in turn will kill bearings. That is one reason why i want to get the ATI super damper for my build. Just something for you to think about. There is a reason why V8's uses balancers.
I did a accord that had a bad pressure plate and i remember how much vibration that caused.
yea call me some time this week.
thanks for the input.. i'm really thinking that i killed my main's coz of the tranny. It's seeming very possible at this point.
:gtfo:
I didn't see that kind of wear on your thrust bearing. I saw squished mains. I'm stickin' to the soft bearing + 20 PSI beating theory. Anything laterally affecting your crank would not have squished the mains like that. It would have eaten through the thrust bearing first.
I've fragged 3 transmissions' thrust bearings, blown 1st and 2nd apart, shatterred my shift forks, and fired a chunk of something out of the tranny case... and all the while running an ACT2600 extreme clutch. I have NO crankshaft endplay. But I do have hardened bearings that are designed for a turbo car.
A little knowledge from a DSMer... If this were true, your engine's thrust bearing would be hosed. If you're thrust bearing were hosed, then you would have crankwalked a Civic.
:gtfo:
:gtfo:
just some food for thought.
*edit: on a side note. I tore down my extra trans to change the input shaft bearing in it coz it's gonna be put to use while i'm fixing the one thats in the car. I'm thinkin i'm gonna toss my extra LSD in there as well & put it back together. I found the input shaft bearing in a different trans that had a cracked case. Cross referanced the part numbers and they came back the same so i didn't have to buy parts yet!
