After a couple years of waiting.......I get to start my GSR build
Old Nov 2, 2008 | 02:05 PM
  #121
Jafro's Avatar
Jafro
I'm made of meat!
Originally Posted by Running925
dude, i forsee bearing failure.
pull the pan asap, check all bearings. There is copper in that first & last pic. better safe than sorry bro.
(making phone call now.. just to make sure u get this message in time.)
1st.... omg, can you take any worse of a photo than this? doesn't your camera have a flower button on it for close-ups?
I will agree that it looks like there's some flakes. Indeed you did the right thing cutting the oil filter open. It's ALWAYS the right thing to do (I did it with your old cx's motor ) whenever you build or rebuild an engine.
The only 2 places that THAT color material could come from is 1) main bearings 2) rod bearings 3) valve guides. That's it. Verify that the flakes aren't part of the filter material by taking a toothpick or razorblade and try to flip them around on the filter material. If they move and are not part of the filter material, start cussing.
start cussing= pull the pan and do what tony suggested. Bearing failure sux. Bore gauge and micrometer for all measurements. Make sure they're properly calibrated by checking them both against something with a known measurement. * Make sure the thing you're measuring for references is the same temperature when testing against another tool *
Old Nov 2, 2008 | 02:08 PM
  #122
Jafro's Avatar
Jafro
I'm made of meat!
*** also... didn't you change all of the oil seals on the timing side?
Old Nov 2, 2008 | 07:26 PM
  #123
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
The Problem is the Number 1 Main bearing. The oil leak is from the oil pan gasket.
^ number 2 main ^ number 1 main
^ number 3 main ^ number 5 main
^number 4 main
Number 1 main
number 2 main
Number 3 main
Number 4 main
Number 5 main
Number 1 rod cap
Old Nov 2, 2008 | 07:30 PM
  #124
HatchVX's Avatar
HatchVX
Number 2 rod cap
Number 3 Rod Cap
Number 4 Rod cap
Old Nov 2, 2008 | 07:33 PM
  #125
white_n_slow's Avatar
white_n_slow
it's my D in a B
focus!
h:
Old Nov 2, 2008 | 07:36 PM
  #126
HatchVX's Avatar
HatchVX
My camara is the suck with no flash on. The shutter takes forever to close.
Old Nov 3, 2008 | 05:16 AM
  #127
Running925's Avatar
Running925
Your Powder Coater
Yes, i'm amazing!
anyways, whats your cold start oil pressure been like?
Old Nov 3, 2008 | 07:36 AM
  #128
HatchVX's Avatar
HatchVX
If i remember right it was right around 20-30 PSI. and around 3k it about 80-90 PSI
Old Nov 3, 2008 | 07:43 AM
  #129
Running925's Avatar
Running925
Your Powder Coater
thats odd.. cold start should have been up above 60's
Old Nov 3, 2008 | 08:34 AM
  #130
HatchVX's Avatar
HatchVX
i cant be certain on the cold numbers but the other i can
