What would this motor handle for Boost?
should i resurface the head after work like that? im assuming they resurface the block when they sleeve it. Out of curiosity, does anyone know of any east coast locations that sleeve honda blocks?
Originally Posted by eonsx311
what does a sleeving job cost? could i get away with a block guard for sleeve play?
Wow im retarded. Sorry about that bro. I have a friend in Cali who is on 400+ hp on stock sleeves and hasnt cracked one yet. Although that is definitely pushing it, but he is a professional builder.
As to your question, sleeves range anywhere from $800-1000 depending on what kind + labor. I wouldnt advise going with a blockguard as it causes overheating problems, plus you have to go to a shop to get them to sit it flush on your block. Running925 feels differently and im sure will post up...however me and many others feel this way.
& NO YOU DO NOT HAVE TO GO TO A MAHCINE SHOP TO HAVE IT PUT IN
you use a rubber mallet!
Actually, i take that back....stock z6 or y8 sleeves can take a lot more than 220whp. I was thinking about stock pistons and rods!
Originally Posted by Running925
yes i do feel differently.. & when you show me that YOU have had a heat problem with it then you can state that you have a valid point.. but until then.. your definatly talkin out your ass .. i have run them my self & have had no problems.. when summer rolls around i'll push 20psi through my stock sleeved / block guarded block & show you that there are no heat problems.. there is a big difference in the water jackets in certain block guards.. some are small some are big but what u really should look at is the flip side.. look at the holes in the head & how big they are & compaire that to the size of the block guard.. when u do.. you will see that the passages in the block guard will out flow the head thus the reason that there is not a problem.. & they are also aluminum so they disipate heat the same as the block.
Wow dude...chill out. I cant say that i personally have had problems with them but i have had friends that had problems. Relax and dont take everything to heart. When i brought your name up, i wasnt saying it in a bad way, i was just saying you feel differently cause i remember how you argued with oscar over it.
honestly i'm kinda in an uproar over this stuff because your saying things that arn't true. I don't wanna see someone with limited knowlage on a subject make a bad decision based on false information that they have gathered from here. There is nothing wrong with block guards.. that is some kinda rumor that started a long long time ago & is false unless the block guard has so small of water passages that they almost turn the block into a closed deck situation. People are generating amazing numbers such as 400-500hp using block guards with stock sleeves & for the cost of a $75 block guard that you can install in your own garage.. the results are amazing!
Honda Civic EX Vtec del sol Si 16v SOHC 1996+UP
Engine
Code Stock
Bore Includes: Kit #/Price
D16Y8 75mm Complete Gasket Set
Cometic Head Gasket
WISECO Forged Pistons
(75.5mm bore and 8.5-9.0:1 comp ratio)
ROSS/Wiseco Pistons (Stock Bore 75mm)
(add $100 to kit price)
Performance Rings
Performance Wrist Pins
TOGA HP Main Bearings
TOGA HP Rod Bearings
Thrust Washers
Timing Belt
Expansion Plugs
Additional Parts Available (not included in HP Kit):
Connecting Rods (Eagle/SCAT/Oliver/Pauter) EKH31MPX
$899
w/Stock Bore 75mm
$999
Following Kits w/TOGA HV Oil Pump
EKH31MPXG
$1009
w/Stock Bore 75mm
$1109
Call to Order:
(603) 378-0090
*found this at a shop that is right over the border in NH (no tax) only thing it dosnt have is rods (ill just call them to see of they would give me a break on price if i throw some in) this look like a good deal? im new to engine tech so so any time saved on finding parts from a parts list will be used in the extremely slow pace i will be working at..
Engine
Code Stock
Cometic Head Gasket
Performance Rings
Thrust Washers
Timing Belt
Expansion Plugs
$899
w/Stock Bore 75mm
$999
EKH31MPXG
$1009
w/Stock Bore 75mm
$1109
Call to Order:
(603) 378-0090
Ok that's fine...Since you have obviously had more experience w/ them, we will leave it at your call. The guy already stated he isnt going that path and afterall it is his final decision whether to or not. Im not arguing with you over this and turning it into some big grudge. I respect your knowledge and leaving it at that. I was simply stating what i have seen and thats it. This convo just ended.
