Why not a H22A
Old Oct 29, 2005 | 09:06 AM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
you own a burasu!
Old Oct 29, 2005 | 01:11 PM
cvchtchbck92's Avatar
cvchtchbck92
Anti-Ebayer
Thanks everyone. I will take everything under consideration.
Old Oct 29, 2005 | 01:22 PM
cvchtchbck92
Anti-Ebayer
Originally Posted by Wharbone
I would love to do a H22A swap. There is a little more work to the swap like Civic2Scooby said. You need custom motor mounts and custom axles are recomended. You also have to cut your shifter hole a little bigger. Here is a good write-up on the swap. http://www.honda-tech.com/zerothread?id=650329
It is an engine with tons of torque.
To settle the weight issue arguement, look here where they weigh a H, B, and D.
http://www.honda-tech.com/zerothread?id=684550
Thanks for the sites. I looked into the weight issue and the guy makes good arguments about the weight difference. I'll look into the first one as well.
Old Oct 29, 2005 | 06:44 PM
Civic2Scooby's Avatar
Civic2Scooby
Originally Posted by JoePannone
you own a burasu!
I own both h: I still have my b16a swapped civic too...winter beater h:
Old Oct 29, 2005 | 07:46 PM
BOOSTED-EK's Avatar
BOOSTED-EK
It's slow...
Go for the h series... ive always wanted to do it. I even thought about selling my b18b just to do the swap but havent had the extra cash yet....
Old Oct 30, 2005 | 12:17 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
The h series uses cables instead of rods for shift linkage. Alot heavier than a b series and more money to swap in. I would go with a b16b, its not in every other hatch and its got alot of power. so like 95 civic asked; what are you plans for this car. If your boosting then i would go with an ls motor. but if going all motor the best would be b16b. imo.
Old Oct 30, 2005 | 12:28 AM
Civic2Scooby
hhahahahahahahahahaha....you talk about stupid...the b16b is such a JDM bling motor....and if you actually read anything in this thread than your entire comment is void...and last time I checked the b16b to swap in is more expensive than the H swap including the HASport mounts to put the H in.
Old Oct 30, 2005 | 12:34 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
Wwhat i was saying is that it is more time consuming and takes more know how to put a h22 into an eg chassis then a b series. thats all.
Old Oct 30, 2005 | 12:38 AM
AcuraFanatic's Avatar
AcuraFanatic
If you want something that is less work than swapping an H22, you could do a B20, boost it, and then do a B16 or B18C1 head swap down the road.
Old Oct 30, 2005 | 12:42 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
Yeah the b20 is the cheappest but it is also the most expensive to build. I had one in my hatch and i blew it after 5 months and 15 lbs. I wanted to sleeve it and it was a shit load compared to other b series motors. I called darton to see how much sleeves would be and they said they didnt make them anymore because they had too many problems.
