Good Coilovers?
Originally posted by i want a civic
can someone explain what is "true" coilover and whats not? does it really matter? thanks.
A "true" coilover is an all inclusive unit where the threading is already on the shock. The spring still sits on dual locking nuts, but the spring rates coincides with the dampening of the shock. Plus most of the time, the spring is a progressive wound spring and usually includes upper pillow mounts. These are application specific so they would be most beneficial for the car that it's going into.
In terms of being the same. If you just need something that can raise and lower your car, you're better off with the GC's and a good set of aftermarket shocks (to prevent bottoming out). It's easier on the wallet which in turn could help you buy other beneficial suspension parts (like bars and bushings and whatnot).
the only draw backs to a sleeve type system is if the sleeve gets cockeyed...or if the shock somehow fails. Ive also heard of perches cracking, but thats certainly possible with a "full" type as well.
in terms of workmanship sleeves or "full" types are both just as likely to fail...so thats not an issue.
I recommend custom rate Ground Controls and Koni Yellows :thumbup: I got 350f/400r and the car handles very nice. Little rough on PA roads but liveable.
Autocross Help Page
Autocross Help Page
I have NEUSPEED coilovers and my 2000 Civic Si..the handling with these is greatly improved and ride is almost like stock. These are great in my opinion.
Brand new they go for $1050 i think. If you want to buy used ones email me cause i plan on buying a new set in a month.
eraxpres
Sep 25, 2003 04:02 AM
Drag3GS
Sep 21, 2002 12:01 PM
pimpingacura
10
Jul 21, 2002 03:27 PM
Chiuey
Prelude
2
Jul 13, 2002 09:17 AM
