Vvvvvvvvteeeec!!!!!!!!!!hhh!!!!1-``~!
Old Oct 13, 2004 | 07:36 PM
Kai's Avatar
Kai
Rotorphile.
Originally Posted by XCM828
nope thats wrong. the e in vtec-e stands for enhanced performance.
Congrats, you're wrong.
VTEC-E is an economy system. It literally "turns off" one intake valve per cylinder at low RPM's to save gas, the valve opens only enough to prevent fuel from pooling on the deactivated valve. It was introduced in the '92 Civic VX on the D15Z1 engine.
It's VTEC-Economy.
D16Y7 just has DOHC.
Just... no.
Originally Posted by oscar_425
Only the Civics HX are VTEC-E
The VX had it first, it was followed in the next generation by the HX.
Old Oct 13, 2004 | 07:39 PM
2gr84u's Avatar
2gr84u
2gr84u
your friends hatch is probably hanging with you cuz hatches are genneraly lighter then coups and sence the power differences are slight he might very well be able to run with you.
Old Oct 13, 2004 | 07:41 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
nope thats wrong. the e in vtec-e stands for enhanced performance. Its on D16Y5's. D16Y8 has SOHC VTEC and D16Y7 just has DOHC.
D16Y8 is SOHC VTEC
D16Y7 is just DOHC??????????
wow...thats new to me.
Old Oct 13, 2004 | 07:44 PM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
D16Y8 is SOHC VTEC
me too! i'm gonna have to swap out the y8 for a y7. thats a sleeper waitin to happen
Old Oct 13, 2004 | 07:50 PM
XCM828's Avatar
XCM828
stay off of wet roads
It's VTEC-Economy.Just... no. The VX had it first, it was followed in the next generation by the HX.
Actually I think we both may be right. The Haynes Manual for my car says that VTEC-E is Honda's designation for "enhanced performance."
However, I did some research and found this site. I quote, "The two engines are essentially the same except for the VTEC-E in the Civic HX. But the Civic HX's VTEC-E mechanism results in 115hp, versus 106hp from the Civic DX. So the Civic HX has more power in addition to better fuel economy. But make no mistake, VTEC-E is designed with economy as the primary goal, not power output."
Draw.
Old Oct 13, 2004 | 07:51 PM
XCM828's Avatar
XCM828
D16Y8 is SOHC VTEC
woops sorry bout that. im tryin to type fast - that was just a typo. SOHC is what i meant. i mean come on the s and d key are right next to each other so you cant blame me.
Old Oct 13, 2004 | 07:54 PM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
Draw.
first of all, haynes manuals have errors. off the top of my head, it mis-codes the D16y8 and is wrong for the hp...i think it states the y7 is in the EX. 2nd, its SRS schematics and locations of parts is off. they are merely reference, not the law.
2nd, the d series are ALL basically the same, just minute intake/fuel/cam changes and tuning (for ease of stating a point) the d16y8 (only in the EX) is 127 hp SOHC Vtec
Old Oct 13, 2004 | 07:57 PM
Kai's Avatar
Kai
Rotorphile.
However the original VTEC-E lagged 10 horsepower behind the DX.
D15B7 (SOHC): 102hp
D15Z1 (SOHC VTEC-E): 92hp.
I would like to know what it is about the later VTEC-E that gives it a boost in output though.
Old Oct 13, 2004 | 08:00 PM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
My guess is that honda took different approaches to fuel economy....previously it was less power AND vtec= better economy, whereas you can peak more power on demand w/ the newer, but they use the same technology to cut back under less throttle.
Old Oct 13, 2004 | 08:06 PM
XCM828's Avatar
XCM828
Jeez my bad dude. Didn't know this subject was so sensitive to you.
And that point would be.....
