Quick spring question...
Old May 10, 2004 | 09:52 AM
shivers's Avatar
shivers
Moderator Alumni
In order to keep your springs from compressing, you'll need to get spring rates that are a LOT stiffer than the shelf rates. Rolling your fenders involves rolling a specialty tool or baseball bat along the lip on the underside of the fender to bend it up and out of the way to reduce tire rubbing in the wheel wells. There should be some posts about it somewhere around here. Try and search and see what you come up with.
2005 s2000
Old May 10, 2004 | 09:55 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
Originally Posted by 98WhtCivicEx
How do you recommend I set the shocks? Should I have the back set to 5 to be firm and the front set to say...3? Would that help out at all?
riding with the shocks at anything other than full soft for daily driving will do nothing but wear out your shocks faster and make the ride unpleasant... Just leave 'em at full soft unless you're doing some spirited driving or an autocross.
Old May 10, 2004 | 09:57 AM
98WhtCivicEx's Avatar
98WhtCivicEx
^^That's Me!^^
Wouldn't rolling my fenders bend it to where it causes bad dents in the fenders or no? I suppose I will haveto do a search and hope to come up with something. Maybe pics to show the end result
So, both the front and rear should be at 1? I read somewhere that you usually want the rear a little stiffer then the front to better traction and what not...Is that true or?
Old May 10, 2004 | 10:06 AM
white_n_slow
it's my D in a B
sure, if you're racing.
I race with the rears set at full stiff and the fronts at 1/4 (mostly soft). But just for daily driving, its not gonna make enough difference to be worth the rapid wear and harsh ride. I ride on full soft all around (Koni Yellows).
Bl@ck
92+ Civic/EL & Del Sol
16
Jul 15, 2004 09:57 AM
crackmatic99
Accord
3
Apr 27, 2004 06:43 PM
sirDANG
May 13, 2003 10:45 PM
CleanAccord
Accord
3
Jan 7, 2003 08:56 AM
madeiniraq
Jun 24, 2002 06:46 AM
