It has begun...
Old Apr 10, 2004 | 12:19 PM
bambbrose's Avatar
bambbrose
i do.
Old Apr 10, 2004 | 12:31 PM
EGteknikhatch's Avatar
EGteknikhatch
Team Teknik
wow this makes me want to boost my b18c!
Old Apr 10, 2004 | 01:42 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I won't divulge my price, but I can get anyone a good one. h:
I'm also condsidering selling my rod/piston set. I'm going to mic my pistons and put them up in the FS section with rods and new rings. Be on the lookout for them.
I also spoke to my Hondata tuner today and he said if I were to go with the setup I have in mind I would easily hit 400whp pushing under 20 psi. BUT, if I were to bump up to 720 cc injectors, I could make ~600 whp at around 24 psi.
I think I'll be happy with 400 whp.... for now. :rick:
Old Apr 10, 2004 | 02:21 PM
cobbcustomz's Avatar
cobbcustomz
600hp Not bad for a 4door :fawk:
j/k great work tho any idea on a time frame til its all up and running?
Old Apr 10, 2004 | 02:24 PM
westcoaststyle
AEBS says 2 weeks turn around time on the block. We'll see after that.
Old Apr 10, 2004 | 02:29 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
damn, 2 weeks is pretty good. They must not be very busy h:
Old Apr 10, 2004 | 09:56 PM
Kai's Avatar
Kai
Rotorphile.
So, when you're done, I can take a trip to AL and drive it, right?
Right?
I'll let you drive my mighty 120 wheel horsepower RX-7... maybe even 200 (13BT swap) by then. h:
Old Apr 10, 2004 | 10:11 PM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
So why did u take the axels out of the hub :dunno: Also are u planing on doing something with the head i see u have it striped?:closeup:
Old Apr 10, 2004 | 10:19 PM
westcoaststyle
I have to remove the tranny to get the motor out... hence, the axles being removed. h:
On the Bseries heads, you have to remove the cams to get the head bolts out. h:
Kai: come on over, we'll work something out.
Oh... and check sig \/ :rick:
Old Apr 10, 2004 | 10:25 PM
Jafro's Avatar
Jafro
I'm made of meat!
...I also got in contact with a guy that does mandrel bent IC piping so I'll be doing that too once the block is back...
:thumbup: Make those pipes the same diameter as your throttle body. Recirculate the BOV into the intake if you can.
You might want to look into water injection to help keep detonation under control. That IC helps alot, but I'd be concerned about pushing 20 PSI with 9.5:1 pistons unless you have some way of monitoring knock. Water injection works great for that if you're running more than 17 PSI of boost.
