Engine Paint
Old Jul 23, 2002 | 07:14 AM
dmparri3's Avatar
dmparri3
Default Engine Paint
Has anyone painted their valve cover and exhaust manifold heat shield?
I am wondering what I need to do to prep the surface. The valve cover looks good and doesn't really need paint, but the heat shield has all these little rust spots and could stand some preservation. I know that it needs to be sanded, but do I need to use a special hi-temp primer or do I just start layering on the paint?
Thanks in advance!
Old Jul 23, 2002 | 07:30 AM
skubb's Avatar
skubb
not that TLC sh!t either
use very, very high grit paper on the heat shield. I used like some 800 and scuffed it to shreds. also clean it over and over again. also make sure you let the paint dry atleast over night and let it idle and cure on the engine before taching it all over town.
if you haven't caught on I did a quick rush job and within a month it was cracking. thank god I didn't try the valve cover
Old Jul 23, 2002 | 08:03 AM
Paul's Avatar
Paul
Eater of Rice
duplicolor makes awesome engine paint and clearcoat, degrease the valve cover, get every single nook and cranny because if there is ANY oil, grease the paint will not stick. good luck. dry for several several hours
Old Jul 23, 2002 | 10:17 AM
white lightnin's Avatar
white lightnin
I used BBQ grill paint on my rusting header flange. Its holding up great.
Old Jul 23, 2002 | 11:41 AM
dmparri3's Avatar
dmparri3
Thanks for all the responses.
Do I need to use a high temp primer after prepping the surface, or is it okay to just use the paint by itself?
Old Jul 23, 2002 | 11:51 AM
white lightnin
I used it by itself hasnt been on for long though. Bout a month.
Old Jul 24, 2002 | 07:02 PM
civickid77's Avatar
civickid77
I got my Duipcolor from wal mart and its been on there a while and still looks good i didnte even prepare the surface i just made sure i degreased it 1st
F Double
Showroom
4
Aug 15, 2005 11:37 AM
19.3secS2K
Showroom
20
Oct 29, 2004 08:24 PM
dicivicHB
Showroom
6
Jul 29, 2004 10:42 AM
Spec R
Dec 3, 2003 01:09 AM
