Subbie Krew... need your help
Old Mar 31, 2010 | 08:08 AM
  #41
white_n_slow's Avatar
white_n_slow
it's my D in a B
Doesn't the RS have upgraded suspension & brakes compared to the base model too?
Old Mar 31, 2010 | 08:11 AM
  #42
Civic2Scooby's Avatar
Civic2Scooby
ah yes, slightly higher spring rates/dampening and bigger brakes, bigger sways...I knew I was forgetting some shiz. Oh and lets not forget you can't get the 2.5l motor in anything but the RS, though if you are swapping that doesn't matter.
Old Mar 31, 2010 | 11:53 AM
  #43
Spec R's Avatar
Spec R
oh yeah, while thats on topic, whats the stock diff setup on the 99 RS? open front, viscous LSD center, viscous LSD rear?
sorry man for all the questions
DB Squad
Integra Forum Moderator
Old Mar 31, 2010 | 06:06 PM
  #44
Civic2Scooby
negative 99 = no LSD. I swapped an 01 rear end into my 99. You can pick them up for around 250 bucks with axles online if you look around. I would consider this a MUST DO modification.
Old Mar 31, 2010 | 07:02 PM
  #45
Spec R's Avatar
Spec R
u rock for knowing.
u suck for bearing bad news.
DB Squad
