Official help me decide my future car
if you like the Legacy GT you should look at the L.L Bean Outback. Same "nice" interior, taller ride height and it has the H6. I dunno if canada has them but you can also look for an Outback Limited which is the same as the Legacy/Impreza but again taller ride height with the standard 2.5 H4. Lastly and what think is the best of both worlds and fits what you want perfectly is the Forester. Good on gas, built like a fucking tank, and will handle any amount of snow you can throw at it.
Montreal Storm
Montreal Storm
With my Mazdaspeed 6 I have awd and blizzaks but low ground clearance. Not really an issue for me though because most of the parts of town where I might need to jump snow banks, are not the parts of town where I go. If however you need to plow through piles of snow, the Mazda CX-7 has a similar drivetrain and is pretty sporty for a crossover/SUV. Only came out in '07 though so I don't know if it's cheap enough for you, and it'll probably suck down a lot of gas.
Think i might of found something ideal...
2001 MDX, full equipped, only problem is the 107K miles
he's asking 9,500 but i'm hoping i could get it for 9K with taxes. what you thinking?
01-02 MDX is about the worst year you can buy, they changed a butt load of stuff on it in 03 to make up for faults in the 01 model. That and 9k for 107k miles...blek...if you do do it, you better make sure the t-belt and waterpump have been done, front struts, and the sway bar bushings front and rear or it is gonna thump all over the fucking place. That and the swaybar endlinks which had a design flaw in the joint. Also the 2001-2002 MDX suffered from extensive transmission failure like the older TL/CL but DOES NOT benefit from the extended warranty on the transmission like the TL/CL. Good luck!
