Help! Disturbing engine noises
sounds like you have a leak in your exhaust manifold....probably a gasket is my guess. I would say its probably fairly minor because it is only happening when under load.
YOu may also have a clutch going out if you are getting high RPM and low output of power so it may be a combo
Does this help?
donut gasket 10:1
Where do you think the gaskets is bad at?
Detonation?
Originally Posted by Fatewolf
So i have an exhaust gasket bad? Hard to change? this would be the first time ive worked on a d16z6 engine to be honest. I have changed one on my 84 accord but that was a bitch.....
Located where the exhaust header meets the exhaust tubing. As long as the bolts aren't welded on with rust it should take about 10 minutes.
Best way to tell is put the car up on stands and run your hand along the under side of the exhaust path and check for any air leaks while it is running. Take every precaution while doing this and have another person there to help just in case...also to press the gas to add pressure.
Another way is to let it idle and have someone lightly cover the tail pipe while someone revs the engine a little, this should create enough force to create a similiar environment to being under load and the leak should be evident at that point.
Originally Posted by Kestrel
But that would set off a CEL wouldn't it?
