computer help
to test the powersupply, bend a paperclip and stick one end into the terminal for the green wire and the other end into one of the black wires next to the green wire, then plug a power cord into the power supply.
Originally Posted by aux
i bought a power supply tester and the power supply is good. :dunno:. i guess the switch is busted?
also try different p/s on your board if possible. the board could be busted
(sorry if im repeating things, didnt read the thread)
More Black on Black Crime
i got a new mobo, new powersupply. working on it right now. tell ya how it goes.
im so lazy.
btw the studs that go between the chassis and mobo are too big or something so the mobo is just sitting on the chassis. is this bad? only way itll fit the slots in the back
im so lazy.
im so lazy.
im so lazy.
I had the exact same problem on my first build, the cases thermal probe was interferring with the CPU, so i pulled it out, resat it, put new thermal grease on it, and it worked perfect. Doesnt sound like thats your problem though, just thought that it might help?
perfect fit without spacers. if it doesnt boot up imma just take it to the shop ;_;
