computer help
Old Mar 31, 2004 | 09:34 PM
aux's Avatar
aux
More Black on Black Crime
Default computer help
so i built a computer. the problem is no power.
i checked all connections. the switch behind the case etc.
id press the power button and i noticed that the fan on the heat sink would spin for a second then stop.
im guessing bad power supply. what do u guys thnik>
Old Mar 31, 2004 | 09:37 PM
b00gers's Avatar
b00gers
are the connections from the power button on the front bezel correct on the motherboard?
is your ram put in correctly? *beeep*
Old Mar 31, 2004 | 09:38 PM
aux's Avatar
aux
haha. ram is correct. and im pretty sure the bezel connections are right. :wtc:
Old Mar 31, 2004 | 09:46 PM
S2Kev's Avatar
S2Kev
Seems like a bad switch to me.
aux's Avatar
aux
it was a cheap case hmm
Old Mar 31, 2004 | 09:49 PM
b00gers's Avatar
b00gers
try unplugging all the power except the HD? maybe its a weak power supply? :thinking: probably not..but :dunno:
Old Mar 31, 2004 | 09:51 PM
Mike Oxbigger's Avatar
Mike Oxbigger
did u remember to put on the paper insulation washers on the points that the motherboard is attached to the case at? I forgot mine and fried my mobo.
Old Mar 31, 2004 | 09:52 PM
aux's Avatar
aux
i did not do that :wtc:.
b00gers's Avatar
b00gers
:thinking: interesting. maybe the board is grounding out. :dunno:
Old Mar 31, 2004 | 09:54 PM
aux's Avatar
aux
i dont really understand how to put the paper washers between the mobo and case tho?
i just laid the mobo over some holes and put in screws.
pics? :dunno:
