computer help
Old Mar 31, 2004 | 09:55 PM
S2Kev's Avatar
S2Kev
Originally Posted by WiLL
:thinking: interesting. maybe the board is grounding out. :dunno:
I don't use those paper insolator things or whatever. I haven't had a motherboard fry on me yet.
b00gers's Avatar
b00gers
the fans turn on and off, EVERY time you push the power button?
Old Mar 31, 2004 | 09:57 PM
aux's Avatar
aux
More Black on Black Crime
not everytime. btw i forgot to use spacers provided with the motherboard. but everything in the back lined up fine.
qtiger's Avatar
qtiger
What happens when you hold the power button?
Did you happen to wire reset to power and vice versa?
Mike Oxbigger's Avatar
Mike Oxbigger
their should be some screws that are the shape of a hex. they raise the board a couple of millimeters off of the case. i think the washers just go on top.....sorry no pics...its been about 2 years since i did it to mine
Old Mar 31, 2004 | 09:58 PM
Bl@ck's Avatar
Bl@ck
Sinner
sounds like your front panel switch isn't hooked up to the frontpanel IO on your mobo.. i had the same problem when i got a new case for the GF's puter. what mobo is it BTW?
Old Mar 31, 2004 | 09:59 PM
aux's Avatar
aux
ill check the connections again. the fan seems to come on randomly when i press the power button.
Old Mar 31, 2004 | 10:00 PM
aux's Avatar
aux
ECS mobo
Old Mar 31, 2004 | 10:01 PM
qtiger's Avatar
qtiger
Eeeeeeeeeeeeeeeeeeeeeehhhhhhhhhhhh.... light it on fire.
Old Mar 31, 2004 | 10:02 PM
Bl@ck's Avatar
Bl@ck
Sinner
Originally Posted by aux
ECS mobo
model number?
