Starting problem,,,HELP!!!
Old May 13, 2006 | 09:15 AM
SirHybrid's Avatar
SirHybrid
You have a 97 with only 10k on it?!!!!!??!!!
That's either a typo, or you are one lucky bastard.
Old May 13, 2006 | 03:30 PM
vtec rider's Avatar
vtec rider
h22 under the hood
oops, I meant 101,000 lol.
Old May 14, 2006 | 05:36 PM
asheylarry's Avatar
asheylarry
so the engine is cranking over?? you are positive that it is cranking over? i thought it was just clicking? i can tell you that a bad battery will make your car do all sorts of crazy shit. i didnt realize that the car was cranking. if it is cranking strong, then you need to check for fuel and spark. if those are both tthere, then you should check your map sensor.
Old May 15, 2006 | 11:54 AM
murris2002's Avatar
murris2002
Thanks guys,,,I found the problem,,,it was the battery,,apparently it is showing a good charge but not enough to start the engine. The battery just doesn't hold a charge,,,the minute I shut the car off,,,I can't start it up again regardless of how long I've run the car.
I'll get a new battery before I stress the alternator and cause other problems.
thanks again
Old May 16, 2006 | 11:31 AM
asheylarry's Avatar
asheylarry
have your alternator tested too. it might not be charging the batt
Old Jun 1, 2006 | 08:58 PM
alexmar23's Avatar
alexmar23
SuperLude23
My Prelude is doing similar things, it cranks, but delays acouple of seconds before starting. I just had my engine replaced though. How does the fuel pressure affect this? I will look into your other good advice though..thanks..
