h23a dohc vtec motor swap
Hello everyone. I just bought a 1993 Honda Prelude SI 4ws with 61k miles on its h23a and really love it. It has a brand new paint job,no dents, no scratches, perfect everything + a kick ass sound system. I really do love this car, but I would like to swap out the engine for a h22a or this h23a dohc vtec motor http://www.naganojapanese.com/h23a.php. I need to know if anyone has done this swap and if its a better engine than the h22a. It really does look like it would be better and the hp number of 225 is not too bad.
Money is not a problem for me as I make around 900 a week and I also just received a check from my grandmothers death for 20k. I would like to keep the swap to around 3-4k though as I dont like blowing money. Also does anyone know of aftermarket parts that will fit the h23a vtec and if its even worth the trouble.
I have been doing some reading and the jdm 92-95 h22a looks to be a very good motor. I could rebuild it up to have the same stats as a type S I think from what I have read. The h23a vtec sounds very cool, but I cant find any aftermarket parts for it at all.
I think that the h23a dohc vtec would be very cool if it worked with all the some parts as the h22a. Does Anyone know of someone on the board that has a 93ish Prelude Si with a h23a dohc vtec swap?
well nagano is wrong about the years on that motor no h22/h23 was made after 01. they are also wrong about the HP on that motor, it makes 200HP not 225HP. Yes it makes the same as the h22a, the .1 liter nets a small gain in TQ.
if u buy the blue top stock then it will be solid, but people have inherent problems with putting a h22a head on a h23a block to save money. keep that in mind.
personally i think the h22a built for NA or turbo is a better bet. the h22a is all around solid thru its high rev range, while ive heard stories about h23a vtec's having alot of reliability problems in the upper RPM band. of course a stock h23a built by honda is the best bet if u have your heart set on one.
u can build up a h22a for high compression with a high reving head for a few grand assuming you dont build it yourself. i personally have a stock block/head h22a1 and i am satisfied with its performance for the 2 years since i rebuilt and swapped it.
~kris
~kris
I want to hit around 250hp 200torque to the wheels on my Prelude, but I dont think I am going to be able to get to that range unless I swap in a h22a1 and do a lot of performance mods to it. Whats the best way to get to 250hp/200torque TO THE WHEELS with my engine being as reliable as it is right now?
