Need help with performance upgrades
Old Sep 10, 2004 | 10:47 PM
monkey's Avatar
monkey
#212
Originally Posted by CEN7272
You don't really need a VAFC unless you're making major mods to your car, like turbo, camshafts etc. the only reason you would need to adjust the Vtec engagement would be if you got bigger cams and needed to change the point where the car stops making power with the regular lobes....But they do look really cool
you can actually make more power on a stock H22 with just a VAFC just by retuning the fuel maps. Also, you can change the tq/hp curves to a more desirable "flatter" curve with the VAFC.
I/H/E/P/VAFC should make around 180-190 whp depending on which parts.
Old Sep 10, 2004 | 10:48 PM
monkey's Avatar
monkey
#212
Originally Posted by TREKKER
JET will reprogram you chip for $299 and give you about 11 hp, but I don't know if it is whp or just hp. If you FedX it, it will take them about 24 hours. I called them today.
without having the car there, and without being able to dyno tune it, i'm not sure how they're gonna maximize power output.
