please help, need diagram to pass SMOG
Old Apr 29, 2004 | 12:02 PM
brand0n's Avatar
brand0n
Default please help, need diagram to pass SMOG
my car wont pass smog, i swapped in a jdm h22a, used to be a usdm h22a1, do these use different vacuum lines? i would really appreciate any links to diagrams for the egr and other smog necessary vacuum lines HELP please i cant legally drive to work ;(
Old Apr 29, 2004 | 12:29 PM
shivers's Avatar
shivers
Moderator Alumni
JDM and USDM engines have different vacuum lines, sensors, and other various parts. Depending what is causing you to fail, you may or may not be able to pass the test. Hopefully someone with some concrete knowledge will be able to give you specifics on what is different and if it's possible to pass. Good luck.
2005 s2000
Old Apr 29, 2004 | 01:37 PM
hondatech's Avatar
hondatech
Honda tech/eprom hackr
What did the car fail for? Visual? actual emissions? Explain more. Did u try to test it?
Old Apr 29, 2004 | 03:16 PM
brand0n's Avatar
brand0n
it failed the knocks and its throwing a code 12, egr.. i really need a diagram
Old May 11, 2004 | 03:00 AM
drift's Avatar
drift
Flaccid Member
www.helminc.com
if you really give a shit, you'll buy the manual.
Old May 11, 2004 | 02:55 PM
hondatech's Avatar
hondatech
I can get it for you but would you know how to use it? Do you own a vacuum pump to test for vacuum at the EGR? Do you have an understanding of the EGR system? Can your computer read .pdf files?
Old May 11, 2004 | 02:58 PM
hondatech's Avatar
hondatech
I'm sure your not in CA, cause you can't have a JDM engine under the hood here unless it was released in the us market and is identical.
blackcar
2
Apr 14, 2004 09:16 PM
va9072
3
Feb 10, 2004 10:19 PM
JPineda
9
Nov 15, 2003 09:30 PM
209MaX
Engine Swaps, Tech & Tuning
Sep 10, 2002 12:53 PM
MoFo
92+ Civic/EL & Del Sol
4
Sep 8, 2002 09:23 PM
