SCC thinks the R is coming.
Originally Posted by asianautica
If Hondda do decide to not kill off the S2k, I can probably see them using a highly tuned K20 or even a K22. Even a mildly tuned K20 can put out similar to the S2k H20 already. The K20 has so much more potential. If they bring the K20/22 to the level of tune of the current H20/22, I can see them getting around 260-280HP. That would be plenty sufficient if they keep the weight where it is or even take off some weight.
Anyways, the Integra/RSX was always kind of the oddball of the Acura line, being more like a Honda than an Acura. Would the RSX fit into the Honda line to fill the low end sports car void left by the Prelude?
the f series in the s2k has more in common with the hseries than it does the f-series as we know them... it is based off of a hybrid of the two used in the accord-r in some markets called the f20b.
the feel that the SI will be upgraded as the rsx fades out and that a CRX will take the place of the previous si and the si the place of the previous rsx.
:edit:
and the work to be done to the k series would be the same ammount of work that was needed to be done to the h or f series to get it to work in a RWD platform... i dont see it as an entirely huge problem, just and engineering chalenge they will enevitably have to take to upgrade the s2k.
:edit:
Originally Posted by whatever7
I would like to see the TSX coupe, basically a Prelube but with 2k worth of interior upgrade over the current TSX. The coupe should be more expensive than the sedan.
Originally Posted by Kestrel
Except there exists an F series engine that works for an RWD platform, especially when you don't gain power or displacement from the K series. It makes no financial sense to develop a RWD K series derivative.
truth be told i'd wish they would create a new 2.4 liter engine with a square rod/stroke ratio.... but it makes more economic sense to create a k series derivitive.
and the RWD f came out of neccesity.. it's technology is stuck back in the 80's for christ sake.
I think 2.0L is the optimal displacement for a I4. 3.0L for a V6. When you increase the displacement anymore than that, you tend to lose revs. So I don't think a 2.4L I4, even if it has a square bore/stroke ratio will be able to rev very high safely. Also, a square 2.4L I4 would make the bore too big, which either weaken the cylinder or make the engine too big. It will also make the piston too heavy to rev as quickly.
wellt hen they might put a v6 in the next s2k, who knows.. the bottom line i'm concerned abotu is they need much higher torque numbers for the general public to enjoy the car
