LS/TURBO and GSR Tranny?
Old Sep 23, 2003 | 12:12 AM
beafer's Avatar
beafer
Default LS/TURBO and GSR Tranny?
I just got my self a 97 2 door teg that i want to build up. I got it really cheap because it has a b16 in it. I was browsing around and I think to gain some some more ponies, it would seem to be best to go with a LS engine with a TURBO and GSR Tranny? Any inputs?
Old Sep 23, 2003 | 12:27 AM
93HybridCX's Avatar
93HybridCX
Beast from the East
Use the Ls tranny its better geared for FI.
Old Sep 23, 2003 | 02:27 AM
revhappy420's Avatar
revhappy420
get the GSR tranny. shorter gears always=better acceleration.
Old Sep 23, 2003 | 06:22 AM
infamous1se619's Avatar
infamous1se619
If u like cruising on the freeway at top end speeds like 160+ then the ls tranny is the way to go. the gsr tranny will spool the turbo faster and is a better tranny to go with unless ure trying to top out.
Old Sep 23, 2003 | 06:53 AM
Sleeper98GSR's Avatar
Sleeper98GSR
LS stylee y0h
Hmmm...you say you got it cheap because it has a B16? I've been thinking that it would be a bit more than a comparable stock version due to the swap and all, but I digress.
PS:ITR tranny is the way to go.
Old Sep 23, 2003 | 12:41 PM
jeepxj66's Avatar
jeepxj66
The reason the ls tranny is concidered better for the turbo is the spacing between the gears. The longer spacing gives more time for the turbo to run. Typically auto trans cars with stock turbos are faster than standard with stock turbos. This is because the turbo spools up and stays there as the tranny shifts gears. Every time you back of to shift gears your turbo has to spool up again to start making power again. The short ratios in the gsr tranny means you shift it more which means less time with the turbo making power.
Old Sep 23, 2003 | 12:51 PM
honda_pilot's Avatar
honda_pilot
DeeCeeFo'
Simply because its has LONGER gears and you'll be IN boost longer doesn't mean it is better for FI. Bottom line when your drag racing (if thats the intended use of this build) shorter gears will prove more potent. Somewhere between an LS tranny and ITR tranny hence: GSR tranny would always be my pick...but its up to you. You don't want your gears to be too short when you may have traction issues. You'll spin off the line and b4 you know it you'll have to shift into second and so on and so forth...
I say stay with your initial choice...
[EDIT] ^ true point about auto trannys with FI, hence when driving a turbo 5-speed, you have to get better at driving the car and you're shifts will become quicker and quicker and hence less loss of spool. One must learn the car they drive first.[EDIT]
Old Sep 23, 2003 | 01:08 PM
beafer's Avatar
beafer
Its for an occasional quarter mile runs. But on average, this car will be daily driven.
Sleeper98GSR: $2500
Old Sep 23, 2003 | 01:37 PM
MetintegrA's Avatar
MetintegrA
I've got a GSR tranny on my GS. It makes a difference compared to the LS I had before.
Old Sep 23, 2003 | 03:18 PM
3 plus 1's Avatar
3 plus 1
If you can, get a type r tranny. Not so much for the gearing, but because it has a limited slip already on it. Whats the point in building up a badass turbo when you cant put it down to the ground. If you get a GSR tranny put an lsd in it. Match it with a lightened flywheel and clutchmaster clutch and you're set for putting it down.
