Help on Performance Cats?
I've noticed that most people on HAN will recommend carsound cats, and tell horror stories of random tech cats breaking and such. However, on honda-tech you'll hear the exact opposite; that random technology cats are the way to go and carsound cats break etc. etc.
I'm not sure how the laws work in other states, but in CA it is illegal to replace your cat with anything else other than the stock cat, unless the stock cat is impossible to get from the factory. If the cat is carb legal then of course you'll pass smog; not sure if they really care that the cat is different from stock. I got this information from comptech; their hi-flo cats are carb legal but "not intended for highway/road use", and if you ask them why they'll give you the same explanation and quote the same law.
Shingo
Shingo
They're never gonna know the difference between oem and aftermarket. I dont know who you've been talking to on h-t but no one likes random cats that know what they're talking about. Carsound all the way. Even if random cats were reliable, they just dont flow as well as carsounds.
Originally posted by newgsrdriver
There is a white wire coming off the 02 sensor...its there.
The light is lit up all the way RICH, not stoich, correct. Green, all the way to the right. That means the power and ground are OK, but the connection to the 02 sensor is not there.
Look again and tap the purple wire coming from the guage (most probably that red extension wire) to the white wire from the 02 sensor...there are 4 of them I believe, one is white.
Is your car OBDI or OBDII cause it sounds like that cat is from an OBDII vehicle and you own an OBDI motor. Just get another O2 sensor and install it there and wire it up so that it gets power but do not wire it upto the ECU.
Originally posted by 98EX
My friend Mike has already experienced this prob.
I have a random technology High flow on my GSR motor, it is mated to a 4-1 DC sports header, with custom 2 1/4" catback exhaust and I have noticed allot better response at higher rpms, but at lower rpms I do feel that I lost some power.
Yes it is good to have some backpreasure and I do believe that you will lose some with all those, but also remember that our motors are not the best in the lower RPM band, the upper end is where our motors live and that is where this helps the most.
