Help on Performance Cats?
Old Jul 15, 2002 | 09:02 PM
Etylorcen's Avatar
Etylorcen
Turbo Mafia Soldier
Carsound :thumbup: I think nick sells em for like 140 w/ the flanges and o2 sensor bung installed.
Old Jul 15, 2002 | 10:36 PM
dVs's Avatar
dVs
Platinum Member
You mean 199 shipped.
Old Jul 16, 2002 | 09:36 AM
Chrgsr96's Avatar
Chrgsr96
i got another question..........when i bought my gsr it already had a guage pod...oil press..air/fuel...batt volt... newayz they all work except for the air/fuel....so i went and looked at the cat...where i guesss the wire is supposed to plug into and there is like a big bolt or plug or something on there. ...and theres a red wire hanging down right above the cat thats taped off.... was it hooked up before or what??? why isn't it hooked up now..and can i hoook it back up?? and whats weird is when i turned hard left the whole air/fuel gauge lights up like all the little leds go nuts...but then it stops..some one help me..i want it to work
Old Jul 16, 2002 | 09:49 AM
newgsrdriver's Avatar
newgsrdriver
$140 would be an awesome deal!
Carsound is the way to go, and IPS does an awesome job with them. When we sold them, the lowest we ever had them for was $185 shipped, and it was usually $199 shipped.
Old Jul 16, 2002 | 10:17 AM
newgsrdriver
The red wire is most likely the extension wire coming from the guage itself, hooked to the only white wire coming from the 02 sensor (the big plug).
Is it completely off all the time otherwise? If so, the power or ground wire is loose as well.
Old Jul 16, 2002 | 01:10 PM
Etylorcen's Avatar
Etylorcen
Turbo Mafia Soldier
Damn....you can get the blank cat for 90 bucks. I guess you gotta pay if you dont know how to weld hehe.
Old Jul 16, 2002 | 03:51 PM
Chrgsr96's Avatar
Chrgsr96
Just one green led stays lit on stoich all the time and doesn't move unless i turn hard and then the led's go back and forth from left side to right and when i look at the cat there is no white wire to hook up the red wire to.
Old Jul 16, 2002 | 04:43 PM
newgsrdriver
There is a white wire coming off the 02 sensor...its there.
The light is lit up all the way RICH, not stoich, correct. Green, all the way to the right. That means the power and ground are OK, but the connection to the 02 sensor is not there.
Look again and tap the purple wire coming from the guage (most probably that red extension wire) to the white wire from the 02 sensor...there are 4 of them I believe, one is white.
Old Jul 16, 2002 | 07:16 PM
dubcac's Avatar
dubcac
I
Random techs like to snap/crack at the welds
Old Jul 17, 2002 | 11:37 AM
98EX's Avatar
98EX
Insane Wierdo
My friend Mike has already experienced this prob.
