Timing Belt
Old Jul 12, 2003 | 10:57 AM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
Supa teg, Thanks for the great webite on how to diy timing belt. I think im going to do mine myself
Old Jul 20, 2003 | 10:38 PM
95tegRS's Avatar
95tegRS
Im gonna do mine in a few weeks also. Im at about 140K, (it was changed last at 73K).
this time in addition to belt, im gonna also change the water pump and alternator while im at it. Ive had a trouble free car up until now, (hydro tranny bearings gone), so some preventative maintance. for a couple of $100, its peace of mind
Old Jul 21, 2003 | 09:28 PM
JTegLS's Avatar
JTegLS
honda says timming is every 88,000 miles and usually that costs just over $200
Old Jul 21, 2003 | 09:38 PM
DelSolSIinMD's Avatar
DelSolSIinMD
Le Grand Illusion
I'd say the average cost I've seen at a private mechanic is $350 to $450. Avg. dealer price is about $500 to $650. Why? The last dealer I talked to said "Because we use only premium Honda-brand parts." ...which, apparently, contain crushed diamonds or something, to add in that extra expense....
Old Jul 23, 2003 | 02:07 PM
bubbadabulldawg's Avatar
bubbadabulldawg
Actually I think it's jade that they use:thumbup: . When you change the timing belt buy a Honda belt I also would adjust the valves too because you'll have the valve cover off because you'll have to pin the cams on zero with dowls pins while you are installing the belt so everything is on zero/tdc. And I would change the waterpump, and ps, alt and ac belts while you're down there (I personally use Goodyear Gatorbacks very durable belts and they grip the pullys better)and if you got the funds get an underdrive pully set you've got everything apart anyways. If you are going to do it yourself you'll save all that money to buy the upgraded stuff vs paying a mechanic to put in a belt and maybe adjust the valves for the amount they will charge!
Old Jul 23, 2003 | 09:40 PM
drdavidge's Avatar
drdavidge
where can you get the parts cheap?
Old Jul 24, 2003 | 01:46 PM
bubbadabulldawg
For underdrive pullys go to unorthodox racing website and check out their closeout/bargan section you might be suprised what you might find. I paid $100. for my underdrive crank pully and it was nos (new old stock) and they wanted to get rid of it. They changed the look of their stuff reciently (added holes to some pullys) so the item you see on their site might not look like the item you get.
Old Jul 24, 2003 | 02:27 PM
drdavidge's Avatar
drdavidge
i mean for the timing belt and water pump?
Old Jul 24, 2003 | 04:33 PM
bubbadabulldawg
I went to the stealership for the belt and the local foreign autoparts store for the waterpump.
Old Jul 25, 2003 | 06:12 PM
ambition's Avatar
ambition
StillDPG
inlinefour.com
^^has a kit oem waterpump, timing belt, and tenisioner
