bad gas mileage
Old Jul 25, 2002 | 08:34 PM
97teg's Avatar
97teg
I noticed the gas milage falling off in my car so i decided to go down to kragen and pick up some valvoline fuel system cleaner. It was like $8 and said only have to do it once a year. Im on my first tank after the cleaner was added and the cars seems more powerful but could be just my backside fooling me. Now im at about 200 miles with half a tank still left. Before it would get about 250 before i had to refill.
Old Jul 26, 2002 | 01:38 AM
el diablo's Avatar
el diablo
Jeeebus......Help Me!!!!!
Im currently getting about 250-270 miles before a refill. Guessing maybe a fuel system cleaning might help a bit.
Old Jul 26, 2002 | 02:20 AM
shockwave's Avatar
shockwave
yeah fuel cleaning system will help alot.... i know its not the same car but back in the day my old caddy (pimp mobile lol) was getting like 8-10mpg lol cleaned the fuel injectors and fuel filter ect and it shot back up to like 15-17 (i know it seems like **** but im just giving an example lol) someone also told me once if none of that works u might have to actually just replace the injectors... try fuel system cleaning... not much to lose, real cheap..
Old Jul 26, 2002 | 05:29 AM
95acurals's Avatar
95acurals
How do I change this?
I'm going to get some fuel cleaner after work. Might as well since I have to fill up tomorrow morning anyway. I've noticed my car hasn't had a very smooth accelleration or deceleration. My fuel filter hasn't been changed in 105,xxx miles so I'm sure that's the culprit. I do have a question about changing it. Will letting the car sit overnight be long enough to let the gas drain out of the filter? I don't feel like catching myself on fire first thing sat. morning . Hopefully replacing all this crap will help. I'll let you guys know if it worked. Thanks for the help :thumbup:
Old Jul 27, 2002 | 10:32 AM
95acurals's Avatar
95acurals
I replaced the fuel filter and dist. cap today. I also used a fuel system cleaner. I tried to replace the dist. rotor but the screw was too stripped. Gotta figure out a wayt to get that off. the fuel filter was tougher than it should have been. when I went to put the new one on I dropped the bold that clamps it in place into the engine :slap: . good thing i found another one that fit. anyway, I now have 100 miles and I haven't even used 1/4 of a tank of gas. I guess the filter just needed changing. thanks for all the help :thumbup:
Old Jul 27, 2002 | 05:46 PM
drdavidge's Avatar
drdavidge
anyone know how t ofix a hanging brake? new rotors i guess?
Old Jul 29, 2002 | 07:32 AM
GSRacer's Avatar
GSRacer
Shadetree Mechanic
The hanging brake is usually one of two things:
1- Messed up piston - if your piston inside the caliper is not coming out straight it can get stuck at an angle and bind "hang" a brake, you usually just have to replace the piston seal as this is usually what causes the problem, make sure to have a piece of fuel hose handy when you remove the caliper to block the brake line, and have plenty of fluid and a buddy around for bleeding them after you fix the piston
2 - Messed up bar thingies - I know my description is not technical but the pins that connect the moving part of your caliper to the stationary one bind up all of the time, sometimes intermittently, go buy new pins from carquest for 6 bucks and buy some high temp brake grease and lube those b*tches up good, it is also a good idea to clean the guides (tubes that they slide into) with a large pipe cleaner and some undiluted simple green, then blow them out with compressed air (or the nearest girlfriend, cause you know she's got plently of that) and put some grease in them too, i know it all sounds a little phallic but it gets the job done.
If anyone has questions, just reply
-GSRacer
Old Jul 29, 2002 | 09:19 AM
drdavidge's Avatar
drdavidge
im confused..what pins are you talkin about? the 2 bolts u take off when you disconnect the caliper to put on new brake pads?
Old Jul 29, 2002 | 10:01 AM
GSRacer's Avatar
GSRacer
Shadetree Mechanic
Actually if memory serves me right (i am not near my car right now) the bolts you speak of screw into the pins that i am talking about.
typeruz
Aug 16, 2003 06:11 PM
AcC95oRd
Accord
12
Oct 30, 2002 02:21 AM
qwho387
Accord
2
Aug 2, 2002 10:08 AM
sirDANG
92+ Civic/EL & Del Sol
6
Jul 30, 2002 11:13 AM
yellowbastard
Engine Swaps, Tech & Tuning
Jul 6, 2002 09:01 PM
