VTEC Sound?!?
i've heard vtec kick in on preludes and civic si's, but my gsr vtec is very low for some reason!?! i have exhaust and CAI which should hype up the vtec noise but it doesn't. im thinking its my CAI b/c its not name brand?
check your oil... it's normal for vtec engines to burn a quart of oil in 3000 miles.. if you haven't changed your oil in awhile or drive your car really hard , you might be low on oil and as a safety precaution , your engine will shut off the vtec
Did it used to be louder before? Or did you slap on the CAI/exhaust and expect more? If it's the latter I wouldn't worry about it.
Shingo
2001 gsr. gonna check oil. also would ram intake be louder then cold air?
If you want loud, get a hi-flo cat or even a test pipe and don't bother with a muffler.
Not sure why people are preoccupied with noise these days...
Shingo
i have a full cat. i not procupied with noise, i love to hear the vtec kik in though. h22's with CAI screams when the vtech kiks in. but mine is a slight boost throughout from 5,000rpm
Also, you should be hearing a definite boost in noise from 6,000+ rpm. Not sure if I should explain why (you may want to look up exactly what happens on B18C1s versus B18C5s when the big cam switches)
but try driving your car again and see if it screams from 6,000+ rpm.Shingo
