Ran Compression Test, Bad News...
Originally posted by Cliffgump
Why would it matter how many plugs are out? Each cylinder's compression is independent of all other cylinders.
Another thing that matters is your gauge. The internal volume of the pressure gauge & the location of it's check-valve also influence the compression pressures. So its only fair to compare your pressures against someone else's if that's all the same.
