Temp gauge going way high, HELP!!
Old Dec 11, 2002 | 12:45 PM
Meguel24's Avatar
Meguel24
Platinum Plus Member
Check the level and I cant even see it in the opening, ALSO when opened I hear it pull in ALOT of air (WOOOOSSHHHH), Im going down the street to get some A/F, at same time I'll check the fan fuse
Old Dec 11, 2002 | 01:00 PM
crash's Avatar
crash
it could have made the sound if you were just driving it cuz it becomes under pressure. there should be coolant up to the filler neck. i would recomend honda coolant from the dealer if you havent left allready, don't get the orange stuff and should be non-silacate so it is safe for aluminum.
when you get home touch the upper and lower radiator hoses and make sure the are both hot.
Old Dec 11, 2002 | 01:36 PM
XSrcing's Avatar
XSrcing
Originally posted by exzeltus
Since we're on the temp gauge subject,
in my previous car, the needle would point to 12:00
in my gsr, the needle points to 11:00
can any other gsr's confirm this?
thats normal. with redline water wetter, and a small vent at the back of the engine bay, i got my temp to stay quite a bit less than normal.
Old Dec 11, 2002 | 04:38 PM
Meguel24's Avatar
Meguel24
I looked at the coolant resivour and it is at max, so it cant be my coolant level, can it??
Fuse is ok.
fan still not come on
???? DAM, this is gonna cost me some buck, dont have it cuz of holiday shopping done already
Old Dec 11, 2002 | 08:14 PM
Etylorcen's Avatar
Etylorcen
Turbo Mafia Soldier
Sometimes you're resevoir can have coolant in it but the radiator is actually low. Mine is kinda gay like that sometimes i dunno why. Maybe you should just flush the entire system to make sure you got the correct amount of coolant. Or you can just get a aftermarket race radiator and you wont have to worry about your fan coming on My fan rarely comes on. In the mornings the temp is about 1/5-1/4 way. When I then hit traffic and go to stop and go it goes to normal temps a little under half way. Wonder how it would be if I didnt have that damn intercooler blocking most of the air flow.
Old Dec 11, 2002 | 08:17 PM
Etylorcen's Avatar
Etylorcen
Turbo Mafia Soldier
Oh yeah...nice sig, now thats some ass!
Old Dec 11, 2002 | 08:30 PM
crash's Avatar
crash
i think its your thermostat, you can try replacing it, cost like $7 if you get one at like kragen or something.
Old Dec 11, 2002 | 08:45 PM
Meguel24's Avatar
Meguel24
OK I start with hitting Kragens and buying A/F and a thermo. If A/F not solve problem I go to Thermo, if that not solve problem, I'll just take it to the guy that does my major services. Thanks Guy, I keep you posted
Old Dec 12, 2002 | 09:19 PM
IDohcVtecExI's Avatar
IDohcVtecExI
Have you tried lookin at the wires makin sure there is no short in them to the fan? Just a thought...not sure if it'll work but it might help to do that.
Old Dec 12, 2002 | 10:29 PM
Shingoblade-GSR's Avatar
Shingoblade-GSR
Hellsing Agency
I would suggest the above as well (fan switch issue) since you seem to only have problems at a full stop (hence no speed to allow air to move through the radiator).
Shingo
