Attn: Vortech Supercharger Owners
Originally posted by SlprTeg
Do you think the exhaust gas is free energy for a turbo?
Its not the most efficient thing in the world, but it isn't anywhere near as wasteful as lost supercharger intake charge.
Originally posted by qtiger
Gas that overlaps its way straight through the engine just hits the turbo again.
LOL, are u the guy i argued with over this same topic not too long ago? cold compressed air has virtually no energy compared to combustion gas :thumbup:
$1100 plus the hours and hours and hours of tuning right now But that should get better over time.
ITR Exhaust cams have shown decent gains with the JRSC...not bad for the sub $150 you can pick one up for.
Originally posted by BonzoAPD
14.9 isn't a big improvement over the 15.6 stock qter mile time.
It needs to spun faster to be more efficient. its like putting a t4 on your d16 and running 5psi of boost.
DAMIMRED
if you want easy, affordable power while keeping your daily driver reliability, might i suggest Nitrous Xpress Smart System or ZEX???
Hellsing Agency
It looks like JRSC >> Vortech by far. I'm at the point where I'm digging for reasons to get the vortech system....
I still haven't heard feedback from a vortech owner...
Shingo
ps. If I had either JRSC or vortech I might consider running a 20 shot to cool the intake charge....
pps. This is getting to be a dang expensive hobby.
Hellsing Agency
Here's an interesting reply from one of the f00s at the "other" board:
"First off let me explain the fundamentals of a supercharger. A supercharger is made of a a moving part which assists the the engine breathe. This moving part is connected to the belt which is driven of the engine. So if the engine is under full throttle it is building boost some what linear to the revs of the engine.
The roots supercharger is used as a positive displacement. It spins slower than any other blower but it pumps a lot more air per revs. The design was made to help help assist engines gain torque everywhere in the power band. This increase in torque will give you power in the entire powerband as well. Since it spins slower the lubricant is self contained and the unit is sealed and the lubricant isn't required for replacement.
The centrifugal supercharger is used like a turbo except its is driven of the belt rather than exhaust. The belt that drives from the engine sends the force to the inside the unit. Within the unit the gears increase the speed of the compresser wheel. The reason why its a centrifugal is because the wheel will initially pump air in form the inducer(inner side) and when it reaches the target RPM will pump on the exducer(outer side). So the flow from this supercharger isn't linear like a roots blower. This design was made to help propell muscle cars make more power at high revs since they can't breath very well. ( They use an extremely high tech Single Under Head Cam Design dated back to the 1720's)
The advantage of running the roots is that is can build boost right form idle. It will give you of the line better start. The advantage of the cantrifugal is that it will give you very high top end. Both of the two units behave totally different. The disadvantage with the JRSC is that it doesn't have a intercooler. People are using a water/alcohol injection to get the same results.
The Vortech unit since it spins at high RPM (like a turbo) needs an oil supply line and drain line.
The driver's seat the JRSC will feel a lot faster since it has low end torque. The Vortech has its torque at high RPM which makes its power at top end seem insane. The Votech actually starts to come alive at about 5000 RPM Which is just about when you hit Vtec. So it feels like a cam that breaks the laws of physics. The exhaust note resembles a Sportbike. Everyday driving with the vortech will make you shift down all the time, whereas the JRSC will make you give it just a little amount of gas. You won't even need to see over 6000 RPM unless you are at the track. The Vortech will seem like it takes longer to get where a JRSC is already there.
The JRSC will get you better gas milage when you are just piddling around. The Vortech will not help you at all here.
The one disadvantage with the Vortech is that the unit mounts to the tranny. So you might as well buy that ACT extreme clutch w/ SS disc and aluminum flywheel and Quaife differential before you install this unit. Your factory clutch WILL NOT hold at all. Or else you will be seing your self remove it all again.
For street use a JRSC is very practical. Its even more practical than the stock with basic upgrades. The turbo comes some where in between but it opens up a whole bunch more problems. The Votech gives you most top end than any of them. Although, you can size a turbo to give you the most top end.
The JRSC will run out of huff at about 350 HP but the Vortech V5 will make upto 580 HP!! But you can't make this on your engine unless you have the $$$$ to make it happen."
Vortech v5 2000 Si
I know this bbn is an oldnpost... however. I have a 2000 Si and love my v5 supercharger
Hi qtiger,
Thanks for the reply. When I first considered modifying my car, I had considered JUN 3s, then decided too many things could go wrong and opted for a CTR intake cam + ITR exhaust cam. However, my car is a hardc0 daily driver so I was a bit iffy about having to open up the engine. I'd prefer to keep the internals stock. If my car wasn't daily driven I would do a pricey all-out all-motor build-up with JUN 3s.
With either unit I'm aware I could make more power with 2.5" piping ex. such as changing out the comptech header for a kamikazi type; however I'm not looking to break 1/4 mile records. All I want is some reliable and fairly maintenance-free power, and I think supercharging would be less of a headache for an incompetent mechanic such as I. I mentioned the top-end power as a justification for choosing the vortech over the JRSC.
Btw, I remember you from the old skool days of HAN/off-topic. You still post on off-topic.net? If I recall correctly you had a tiger as your avatar hehe.
Thanks again...
Shingo
ps. I have yet to find a Vortech owner on one of these boards..guess I'll have to keep trying
Thanks again...
Shingo
TonyTheFarmer
6
04-03-2004 11:34 PM
