Question about lowering a Type R
Old Mar 23, 2008 | 09:05 PM
jesusublime99's Avatar
jesusublime99
Originally Posted by white_racer
what is a good drop on a type r? If i lower it a 1.5 drop will it still look the same as it does now? or would i need a lower drop to make a differance? say like a 1.7-2.0 drop?
The Type R comes 1" lower the other Integras, so yes, you would need a lower drop if you want your car to look lowered- if you used springs not designed for the Type R specifically.
For example, a set of Eibach Sportline springs will lower a Type R only 0.7", and all other Integras 1.7".
However H&R makes a spring specifically for the Type R which will lower it 1.5F and 1.3R.
Old Mar 24, 2008 | 11:34 AM
white_racer's Avatar
white_racer
THANK YOU
Old Mar 24, 2008 | 11:01 PM
Spec R's Avatar
Spec R
i had the ITR spec H&R's on my LS, and it lowered it a buttload (2.25" plus). i later had stock ITR springs, which lowererd the car about 1.25-1.5" compared to the stock LS springs.
DB Squad
Integra Forum Moderator
