Grinding noise...
When I apply the brakes, I hear a nasty grinding noise coming from the front of the car... The steering wheel feels like if if I have a flat... I thought it was the brakes, but checked that out and they all seem fine... Also the brake pedal feels bumpy when that happens... Any ideas what the problem can be? Thanks...
It happens more often when turnig... The steering wheel turns hard to one side... I inspected thwe brakes again today including arms, bushings.... I cant find nothing wrong and now the noise is getting louder...
Thanks for the help guys...
Sounds like a definite brake problem! It doesn't sound suspension related anyhow. I would not visually inspect it, but try rotating the rotors on the spindle, and eye it from the side. Just make sure the 2 flat head screws are holding the rotors tight to the spindle. In some cases you may have one longer bolt holding the caliper bracket to the spindle, also causing it to grind when turning. Also, check for any grinding chips around the areas.
I've spinned the disks while tire was off and they spin freely... Nothing gets in the way of it... When it happens, it sounds like the pads are rocks, juat a nasty grinding noise, and alot of vibrations on the pedals and steering wheel... Thanks for the help guys, really appriciate it..
Sometimes bad tires will cause a vibration in the steering wheel, but i've never heard of it affecting the brake pedal.
I changed the brake pads(OEM) a little over a year ago, they still look new... I never repalced the rotors since I got the car two years ago.... All the bolts are on tight. Everything else seems to be in good shape, no bending, warping, cracks, etc...... The tires are brand new, just bought them....
Thanks
Thanks
