h22 vs gsr motor
Old Nov 18, 2006 | 07:59 PM
Snoopy's Avatar
Snoopy
been there done that
www.hmotorsonline.com
www.inlinefour.com
www.jhpusa.com
www.whitfieldracing.com
Old Nov 18, 2006 | 08:15 PM
kenny7231's Avatar
kenny7231
do i get oem jdm honda pistons and rings?
Old Nov 18, 2006 | 08:21 PM
Snoopy's Avatar
Snoopy
yes
Old Nov 18, 2006 | 08:22 PM
kenny7231's Avatar
kenny7231
any particular gasket set?
Old Nov 18, 2006 | 08:26 PM
Snoopy's Avatar
Snoopy
oem for every bearing, gasket, seal, etc.
Old Nov 18, 2006 | 08:28 PM
kenny7231's Avatar
kenny7231
thanks man i guess we covered the entire engine on what i need to get!!! thanks for all ur help.
Old Nov 18, 2006 | 08:34 PM
Snoopy's Avatar
Snoopy
:goodjob:
Old Nov 20, 2006 | 12:25 PM
primetime's Avatar
primetime
Originally Posted by kenny7231
well quick daily driver!!!! i got like a 2k budget if i keep the gsr maybe higher what yall think
with a 2k budget you can get more power with a gsr one of the set ups that i have is:
buddy club spec IV Cams $570 from www.kingmotorsports.com
Buddy club Titanium retainers $205 from www.kingmotorsports.com
Buddy club Valve Springs $210 from www.kingmotorsports.com
Spoon JDM Type R Balanced pistons with rings and Wrist pins for $360 from
www.Inlinefour.com
buddyclub Cam gears for $180(exhaust and intake) from www.inlinefour.com
and hondata or some other ecu program. you will need to move the redline to about 9500 rpm and tune!
so your looking at about $1525. in parts not including ecu stuff and tuning
i do know that at www.skunk2.com their ecu tuning package is about $250.
Old Nov 20, 2006 | 01:00 PM
kenny7231's Avatar
kenny7231
www.Inlinefour.com
which set up is better snoppys or primetime. which one will i make more hp/tq??? also with the buddy club i can rev to 9500? can i rev that high with the blox b cam??? thanks
Old Nov 20, 2006 | 01:07 PM
Snoopy's Avatar
Snoopy
buddy club IV's are pretty big cams and would require more compression than itr's can give you. maybe if you also milled the head and ran a thin headgasket. but i dislike both of these methods for raising compression as piston to valve clearence becomes an issue. 9500rpm isnt completely necessary. you should only rev as high as you make power. so if power drops off at 8500, no need to go any higher. and that setup is basically only for the internals, you still need a nice flowing header, exhaust, intake manifold, tuning.
the setup i gave you is very simple and will make for a fun daily driver with some pep.
