Need engine diagnosis....
Old Nov 11, 2006 | 07:23 PM
Bui1t2Spill's Avatar
Bui1t2Spill
Default Need engine diagnosis....
Heres the deal. I had a b18c5 swap in my 97GSR 4dr. It was raining really hard one night and my CAI is really low. It was starting to suck water so i decided to pull over on a ramp and wait out the rain... well there was a big puddle awaiting me on the off ramp. Engine died as i went through it. Got it started later that night....the next day i was driving my car and the block cracked....
I recently got a new block assembly, and had the old head taken to a machine shop and all new valves put in and totally checked out. The motor is all together in my garage now. My friend who is a mechanic has been working on it for a few days. Theres a couple problems though, It idles really rough, vtec does not kick in, and its seems to be smoking quite a bit. He hasn't had much experience with this type of motor so hes kind of stumped.
If anyone has any ideas, id appreciate them alot. Thanks alot.
Old Nov 12, 2006 | 01:07 PM
t3t4delsol's Avatar
t3t4delsol
did you clean your intake mani and tb, reset the computer, its probley smoking because you still have water in your head
Old Nov 12, 2006 | 02:16 PM
Bui1t2Spill
im not sure if he's done all that or not. ill check with him and post again when i find out. thanks for the help
Old Nov 13, 2006 | 02:29 PM
Bui1t2Spill
is the only place you can reset the computer is at the dealer? thats what some girl at advanced auto was telling me last night.
Old Nov 13, 2006 | 03:18 PM
fastback's Avatar
fastback
If the ECU has been disconnected from the battery the whole time you had the motor being worked on, it is already reset.
Old Nov 14, 2006 | 01:45 AM
Bui1t2Spill
hmm well it was disconnected while we were putting the engine in. we've cleaned the tb and imanifold already and put some gas treatment in because the gas was pretty old in there. any other suggestions on what could be causing this? thanks
Old Nov 14, 2006 | 12:49 PM
t3t4delsol's Avatar
t3t4delsol
any cells? also what kind of head gasket?
Old Nov 14, 2006 | 01:12 PM
2001TEGGSR's Avatar
2001TEGGSR
What kind of smoke are we talking?
White, Black, Blue, in the exhaust or on the engine itself?
How long have you run the engine since the overhaul?
Did you get new piston rings in the process?
Are you positive that all vacuum lines are hooked up correctly?
Is the PCV valve hooked up on the IM?
Old Nov 14, 2006 | 03:25 PM
Bui1t2Spill
Its white smoke in the exhaust. we've had the motor running for about an hour max, drove it to an exhaust shop, and just in our garage trying to figure the idling issue out.
the entire block assembly is new from the dealer and it came with new rings.
i just called the mechanic and he said hes sure all the lines are hooked up and so is the PCV.
And the gasket is from auto zone he said.
Old Nov 14, 2006 | 03:50 PM
2001TEGGSR's Avatar
2001TEGGSR
That tells me that coolant is getting into your combustion chamber, somehow. If all the obvious things have been checked, it's possible that your head-gasket didn't seat properly. Did he use a manual (Haynes or Helms) to torque the head bolts in proper sequence and to specified ft/lbs ?
Following an overhaul, there will generally be a minimal amount of blow-by until the rings seat properly. I wouldn't be trying to rev into vtec until break-in is complete. Check your oil to see if it is contaminated with water beeds (coolant). It would be worth while to drain the oil out and look at it. Then replace with fresh oil. Check the coolant as well, for oil specs.
