Whats wrong?
Old Sep 20, 2006 | 10:53 AM
Difussion3's Avatar
Difussion3
Touge
Default Whats wrong?
Since Monday, my car has been acting up when i left work. Ok this is what happens. Im driving, doesnt matter what gear its on, when all of a sudden it starts losing power and the rpms drop. Then after it drops like 2k rpm it yanks again and regains the power. Then again it drops rpms and after like 2-3 seconds, it yanks again and regains it... It only does this for like the first 3-4 minutes of driving and then it runs normal.... anybody know what this might be? Thanks.
Old Sep 21, 2006 | 06:04 AM
HeavyFooted's Avatar
HeavyFooted
That's what its all about
Possibly a vacuum leak, failing fuel filter or even look to see if the pcv is failing.
Old Sep 21, 2006 | 09:39 AM
Difussion3's Avatar
Difussion3
Touge
Well in a few days im going to do a tune-up. I already have spark plugs, fuel filter, pcv valve, distributor rotor, and distributor cap... Hopefully its something as simple as that... plus like 2 weeks ago i used the injector cleaner...
Old Sep 21, 2006 | 12:16 PM
tdeters12's Avatar
tdeters12
check your idle air control valve and circuit this is a common problem especially just after start up or even idling also check for DTCs that should be your first step in your diagnostics
Old Sep 21, 2006 | 04:36 PM
Difussion3's Avatar
Difussion3
Touge
Whats DTC's??
Old Sep 21, 2006 | 04:56 PM
carta79's Avatar
carta79
Life after death
Diagnostic trouble codes, also known as check engine light codes.
Old Sep 21, 2006 | 04:59 PM
Difussion3's Avatar
Difussion3
Touge
ohhh so i should still check the DTS's even though my CEL isnt on?
Old Sep 21, 2006 | 05:07 PM
carta79's Avatar
carta79
Life after death
DTC's!
Do you see the check engine light illuminate then turn off when you turn the key to OnII? If so, I wouldn't personally bother with checking for DTC's.
Your problem sounds like an issue with the fuel supply system to me, from what you describe. Check the fuel pressure and to see if it's within spec.
Old Sep 22, 2006 | 11:04 AM
meangreen96's Avatar
meangreen96
Integra Owner No. 122,019
I say fuel pump........get it checked.
Old Sep 22, 2006 | 02:35 PM
g290ls's Avatar
g290ls
they call me tater salad
sounds like your distributor is going out
