Whats wrong?
Old Sep 26, 2006 | 10:55 AM
Difussion3's Avatar
Difussion3
Touge
anybody else that might think its something else? I just changed my spark plugs and distributor cap w/ rotor... i dont really know how to change the fuel filter and the pcv valve is a bitch to get to... so i guess im going to have to take it to a mechanic cause its really getting annoying...
Old Sep 26, 2006 | 11:40 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
Originally Posted by carta79
Diagnostic trouble codes, also known as check engine light codes.
The Term we use here at honda is malfuntion indicator light, also known as MIL
Old Sep 26, 2006 | 11:57 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
This is a common symptom when the modulator in the distributor begins to go tits up. Eventually you'll be driving and the car will just die and then fail to start.
Old Sep 26, 2006 | 12:16 PM
Difussion3's Avatar
Difussion3
Touge
so does this mean i have to get my distributor replaced or what? I should just take it to a mechanic to get it checked out then...
Old Sep 26, 2006 | 03:52 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
The modulator is inside the distributor. If you replace it your car still does the same thing then it is best to replace the whole thing. Then take it back and say I didn't use this, I just decided I'd rather buy a new distributor from a friend for cheap...
Old Sep 26, 2006 | 03:56 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
That is still wrong. It is a malfunction indicator lamp. h:
Old Sep 26, 2006 | 06:27 PM
carta79's Avatar
carta79
Life after death
The question was, what does DTC stand for, not what does MIL stand for? Who told you that MIL stands for "malfunction" indicator light, Germaine? If you want to get technical with me then let's get technical. Not only did you spell "malfunction" wrong but the acronym you're referring to is MALFUNCTION INDICATOR LAMP, also known as MIL.
So go back to Honda tomorrow and tell them what you learned newb.
wned:
Last edited by carta79; Sep 26, 2006 at 06:36 PM. Reason: Spoonfed thinks he knows what he's talking about because he works at Honda now.
Old Sep 27, 2006 | 11:48 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
wned:
Chill man...Schmoo has been around for a while and he knows what the fuck he is saying, however he is entitled to make a mistake, not saying he did, but relax. It's just a light...
Old Sep 27, 2006 | 11:55 AM
t3t4delsol's Avatar
t3t4delsol
he is not talking about Däs Schmoo
Old Sep 27, 2006 | 12:44 PM
Provocateur
On permanent hiatus
He wasn't referring to me. We was just reiterating what I said and I was correct.
Anyways.....back on topic. h:
Sounds like the ignitor is about to take a shit. Before you do anything, pick up a multimeter and test the ignitor to make sure that is the culprit. If you don't want to do that, just get a new distributor off ebay for like $160 and replace the whole damn thing.
