Best Engine for b00st!
Old Sep 20, 2002 | 07:29 AM
SlprTeg's Avatar
SlprTeg
Originally posted by Stealth 95 GS-R
I know, I am just going on what other people have said...btw, its not just lift that we are talking about...duration and timing and all that stuff affects turbos too, and that is different on a type r cam...
-Andrew
duration is bad for a turbo tho. THe ideal turbo cam will have suepr high lift with short duration..
duration leaks boost thru overlap. You can dial out the overlap but that will throw other things out of wack, such as valves staying open too long.
Old Sep 20, 2002 | 07:47 AM
qtiger's Avatar
qtiger
Common myth. Leaked boost just spills out and hits the turbo, which gives you more boost.
Look at HKS cams for DSMs. They've got 269 or 272 degrees of duration, depending on stage.
Old Sep 20, 2002 | 08:32 AM
SlprTeg's Avatar
SlprTeg
Then why are all of the turbo cams for our cars short duration and high lift?
Also the turbo creates so much backpressure, that exhaust can revert back into the cylinder from excessive overlap.
I dont think leaked boost can spool the turbo like you think it can... i think the cons outweigh the pros.
Old Sep 20, 2002 | 09:55 AM
qtiger's Avatar
qtiger
Because they're designed for streetability and gas mileage. All the turbo cams on the market are midline cams.
Where do you think leaked boost goes?
Old Sep 20, 2002 | 09:58 AM
SlprTeg's Avatar
SlprTeg
It goes to boost heaven :thumbup:
Old Sep 20, 2002 | 10:25 AM
qtiger's Avatar
qtiger
Old Sep 20, 2002 | 11:12 PM
g2tegls's Avatar
g2tegls
MR, ftw
I have a question about compression and psi. Let's say you have a b18c1 with 8 psi and a b18c5 with 6 psi from a turbocharger. Let's pretend they're making the same amount of power because the c5 has higher compression. Which is better? Is one or the other causing more stress on the engine?? Thnx.
Old Sep 21, 2002 | 12:39 AM
SlprTeg's Avatar
SlprTeg
The type-r will have higher cylinder pressures, making it worse.
Old Sep 21, 2002 | 01:48 AM
lttletimmy's Avatar
lttletimmy
I would have to go and say that the B20 is better than both of those for boost. And if you don't want the B20 then go with the B18A or B18B. VTEC doesn't react as well with boost, the non vtec motors have a slightly higher displacement, and they have lower compression. Much better for boosting in my opinion.
Old Sep 21, 2002 | 05:14 AM
stealthteg's Avatar
stealthteg
Some dude where i live slapped a turbo on his type-R.. he tuned it a little bit and now runs 12.02 at the track. his car fly's and there is no problems..just make you buy the right parts for the right job...
