ACT vs Exedy
Old Mar 17, 2006 | 05:55 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Originally Posted by rugsr
pressure plate as in what, "the clutch" your talking about the XTSS right. theres nothing else to buy but the clutch right?
hmm see i ve taken a look at the F7.5lb flywheel and everyone says NOOOO to 7.5lb with a turbo. many have said 10-12
Ill go with ACT XTSS clutch and probably the ACT streetlite.....as long as no one else says the 7.5lb are good for turbos. Near 300HP
A 'clutch' is 2 pieces: the pressure plate and the clutch disc.
Here's the breakdown of the ACT part number methodology:
The XT denotes an Extreme pressure plate: http://www.advancedclutch.com/produc...lates_info.asp
The SS denotes a Super Street clutch disc: http://www.advancedclutch.com/produc...GSR%20Type%20R
I was making 457 whp and about 320 wtq when I sold my car - B18C1 turbo. I was running a 7.5 lb clutchmasters flywheel without any problems. People that tell you things don't always know what they're talking about. They simply continue to propagate rumors and "I've heard's" from the Internet and those that don't know. I've done it, I had no problems. 7.5 lbs will be just fine.
Old Mar 17, 2006 | 06:33 AM
rugsr's Avatar
rugsr
How do my taillights look
7.5........really? hmmmmm. man i wish someone around here would just have 2 of the same car boosted with 2 different flywheel and let me test it out HAH.
SO when i pick up a ACT-XTSS im getting the whole kitten-kabootal. nothing else to buy right. just need a clutch and a flywheel
Old Mar 17, 2006 | 06:47 AM
westcoaststyle
Any kit you get from ACT or a redistributor will include:
clutch disc
pressure plate
throwout bearing
alignment tool
pilot bearing
You will have to purchase the flywheel separately, unless the seller is offering a package deal.
Old Mar 17, 2006 | 07:40 AM
rugsr's Avatar
rugsr
Right Right, Ok Good
Just Got Done Talking With A Fe Wother People And They Said On There Boosted Gsr Making 400hp A 7.5 Flywheel Was Fine Too
Only Thing Though Is The Fidenzas Arent Chromeoly
Old Mar 17, 2006 | 08:07 AM
Exadar's Avatar
Exadar
Be Quiet and Drive
I'm pretty sure you won't be creating enough heat to need to worry about it being aluminum... but I could be wrongh:
Old Mar 17, 2006 | 08:53 AM
rugsr's Avatar
rugsr
anyone else wanna comment on that^
Old Mar 17, 2006 | 11:26 AM
rugsr's Avatar
rugsr
what about the ACT Prolite 8.8lb
Old Mar 17, 2006 | 12:03 PM
westcoaststyle
I've installed prolites. They're pretty nice.
Old Mar 17, 2006 | 12:23 PM
rugsr's Avatar
rugsr
big difference between 7.5 and 8.8 ?
Old Mar 17, 2006 | 12:26 PM
westcoaststyle
Yes. 1.3 lbs.
Not really man. You'll be fine with that.
