Oil Pan Gasket
Old Feb 20, 2006 | 07:23 AM
  #31
IntegraGSR12's Avatar
IntegraGSR12
I have a haynes and I dont even see engine stiffners in there or the flywheel sheild just the oil pan bolts and it says 92 lbs-in So should I buy the helms book as well???
Old Feb 20, 2006 | 08:30 AM
  #32
Provocateur's Avatar
Provocateur
On permanent hiatus
I got my specs straight from the Integra service manual, so since there is a descrepency, the Helms manual would be a good investment if you want accurate torque specs and procedures.
Old Feb 20, 2006 | 11:42 AM
  #33
greengsr2k's Avatar
greengsr2k
i left my gsr at the shop today. It looks like the oil is leaking from the gasket and is sealed properly. The mechanic will redo everything and fix it no charge. He will also weld my return line better. It looks like its leaking a little there. Hopefully when i pick my gzzr tomorrow . it will be clean with no leaks.
Old Apr 3, 2006 | 06:06 AM
  #34
r1ch79's Avatar
r1ch79
Well finally got to doing it, it worked out well, was pretty easy, header was a *$%#%@^ but i just took my time. Thanks a lot people!
Old Apr 3, 2006 | 06:17 AM
  #35
rugsr's Avatar
rugsr
How do my taillights look
sweet man. no more leaks right? you use hondabond?
anyone have a pic showing which order to do the bolts in?
Old Apr 3, 2006 | 06:30 AM
  #36
r1ch79's Avatar
r1ch79
Nah i didnt use the hondabond, my friend at Acura (Mechanic) said not to. But he copied the manual for me on how to do the bolt pattern, but I threw it out, my bad! I did it awile ago, just never got to posting here. But there was an order in which to put them in and torque as well. I should stop smoking so id remember things more, sorry!
Old Apr 3, 2006 | 07:11 AM
  #37
rugsr's Avatar
rugsr
lol, ye i got the tq but i think the bolt pattern is like start in the middle and the cris cross them across the pan itself
Old Apr 3, 2006 | 08:23 AM
  #38
reno96teg's Avatar
i don't believe the oil pan gasket requires hondabond.
what is EXTREMELY important though is that it is torqued down evenly (crisscross pattern) and correctly. the bolts and nuts don't require much torque at all, so be careful not to overtighten.
Old Apr 3, 2006 | 10:21 AM
  #39
Provocateur
On permanent hiatus
Using hondabond is completely optional. I agree that it needs to be torqued correctly over worrying about hondabond.
Old Apr 3, 2006 | 12:06 PM
  #40
rugsr's Avatar
rugsr
any pics of the crisscross pattern?
