Engine Swap
Old Feb 9, 2006 | 05:54 PM
GhostAce23's Avatar
GhostAce23
Right now I stumbled upon a H22A wit all the fixtures you think I could fit it in the gsr n get it turboed?
Old Feb 9, 2006 | 06:13 PM
Driverman5777's Avatar
Driverman5777
Yea def. How much?
Old Feb 9, 2006 | 06:20 PM
GhostAce23's Avatar
GhostAce23
ionno how much boost the stock engine could support...
Old Feb 9, 2006 | 06:24 PM
Driverman5777
Don't quote me but my guess would probably be like 7 or 8.
Old Feb 9, 2006 | 06:27 PM
GhostAce23's Avatar
GhostAce23
what would i needa to do for it to support 20
Old Feb 9, 2006 | 06:30 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Originally Posted by Driverman5777
But Vtec has higher compression lower is better for boost. If you got a B20 swap and used the intake manifold and such from a teg. You'd have more horsepower, torque, and displacement.
Don't take this the wrong way, but you seriously need to learn more about Honda motors and tuning in general. Get yourself a copy of Mike Kojima's book, Honda/Acura Engine Performance. The ISBN # is 1-557-883-84X. For $15, it is a very good resource to learn from and become familiar with the concepts of power tuning and the specific methodologies of tuning Honda motors.
VTEC is a system that controls the operation of the valvetrain within specific cylinder heads. The VTEC system does not determine the compression ratio of an engine. Secondly, people have been turbo-charging the DC2 Integra's B18C1 motor for nearly a decade. It is certainly capable of being turbocharged reliably.
Thirdly, in CA there are some legal hurdles that make a B20B or B20Z swap de-facto illegal based on EPA classification. So depending on where the OP is, a "B20 swap" may not even be a legal option.
Old Feb 9, 2006 | 06:35 PM
Driverman5777
I never said that a B18c turbo setup wasn't a good thing it is just better w/ a lower compression. And I def. Know that Vtec has nothing to do w/ compression that is the pistons and block and such. The GSR is 10.1.1 whereas the LS is 9.6.1. I probably could benefit from that book but I'm not a complete idiot. U just took what I said wrong its all good. I probably could have worded it better. And I live in MD so most of the things from CA I am unfarmiliar with, and very thankful I dnt have to deal w/.
Old Feb 9, 2006 | 06:36 PM
Driverman5777
You would def. want to sleve the block and beef up the internals, so you don't throw a rod, valve, or anything else vital.
Old Feb 9, 2006 | 06:39 PM
TheOtherDave™
Apathy Kills
What engine swaps would you recommend for my 95 GS-R, plus keep in mind I want to have it turboed.
I would recommend staying with your original B18C1 motor.
I have a number of questions for you..
1) What state do you live in? Is smog inspection an issue where you live?
2) Is the original motor in working condition?
3) What's your budget?
4) How reliable do you need the car to be?
5) Realistically, how fast do you want to go?
Before you answer #6, consider what you're asking the front tires to do and how much the car weighs. A DC2 weighs about 2700lbs, so a solid 300hp to the wheels will be more than enough to get you in serious trouble.
Old Feb 9, 2006 | 06:45 PM
GhostAce23's Avatar
GhostAce23
I live in va. The original motor works but has 100,000 miles on it my budget is 7-8k and I need the car to be very reliable because I wont have the cash for a rebuild because soon enough ill be heading to college and b dead broke and how fast do I want to go? I'm really thinking bout gearing out at 120 so that all the power is working towards that point.
