Idle Bouncing
Old Jan 7, 2006 | 07:50 AM
tek0056's Avatar
tek0056
Ok so when I plug the hole up shown In the picture my idle drops immensely. is that good? I haven’t tried it with the car warmed up yet.
Old Jan 30, 2006 | 11:33 PM
Entrophy's Avatar
Entrophy
I had the same problem. tested the IACV it checked out fine. the next step was a new computer. I had nothing to loose so i opened up the case and it had corrosion on quite a few parts, used a toothbrush and some alcohol and scrubbed off the corrosion and rinsed with water checked and repeated. check the plug connectors for corrosion also. and thouroughly dried with hair dryer. yeah I know what your thinking, water and circuit boards? what a moron.
You can wash them off just make sure you dry them.
Pluged it back in crossed my fingers and started the car.
it ran perfect, no more idle surge no more throwing codes.
try it as a last resort.
Old Feb 3, 2006 | 06:07 PM
timsdailydose's Avatar
timsdailydose
Don't use water, Use isopropl alcohol it will clean better on circuit boards and it will evaporate quicker and better than water . You wont even neet to use a blow drier.
