jackson supercharger in gsr?
Old Nov 3, 2005 | 08:15 AM
rugsr's Avatar
rugsr
How do my taillights look
all of the SC ive heard sounds like screaming wining babies. its like a super ass loud high pitch,eeeeeeeeeeeeeeeeeeeeeeee. not sure if all the ones i heard were f'ed but thats one reason why i didnt go SC. plus turbo leaves ya a lotta room for more HP
Old Nov 3, 2005 | 08:30 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
That is how they naturally sound.
Old Nov 3, 2005 | 09:52 AM
LT's Avatar
LT
The deer had to die!
:werd:
it's called a blower for a reason.
Old Nov 3, 2005 | 09:54 AM
rugsr's Avatar
rugsr
still dont like the sound
Old Nov 3, 2005 | 10:58 AM
DVPGSR's Avatar
DVPGSR
I need sleep...
Nothing wrong with putting a SC on a GSR. However, there is more to it than just simply bolting it up. Plan to spend a good amount of time and money tuning the car to ensure that the car runs properly under all conditions. You do not want to be leaning your car out when you reach VTEC.
Old Nov 3, 2005 | 11:44 AM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
not to mention the fact that the TB is moved about 6-8 inches over so ur gunna have to give ur intake some love w/ the old hacksaw...and yeah it's fun but once u reach a certain point...u run out of options and mods
Old Nov 3, 2005 | 01:11 PM
jay12187's Avatar
jay12187
Personally, I think superchargers sound bad as hell. I wouldnt mess with a guy if I heard his car whine like that. There are plenty of options for superchargers, just not as many as turbos. You can still have a ton of fun with your no-lag boosted set up even though you may not have the growing potential of a turbo. I say go for it and have a blast.
Old Nov 3, 2005 | 02:01 PM
BADST GS-R's Avatar
BADST GS-R
Originally Posted by mean-azz-acura
turbos leave room for almost endless expansion down the road where SC are very limited for boost options. if you know you can live with only a small amount of upgrade in pressure then go for it. you dont seem to want a turbo so the only other decent alternative would be the SC. your money spent on something else wouldnt give anything close to the gains that come with boost. on top of that, they sound so damn cool...
Not true. Yes... you can "turn up the boost" on a turbo. But if you don't have the engine modifications to support the increase cylinder pressure, you'll wind up hurting the engine. If you did do some major upgrades to the engine for more boost, that same turbo might not be the proper turbo for the new application. Just because you can run 8-10 psi on a stock engine, it's very possible that "turning up the boost" on that particular turbo may not benefit you as well as you might think with the new engine. A turbo can lose it's effectiveness if not matched properly to the engine.
As far as being limited on boost options on a supercharger, a simple pulley swap will give you the added boost that you need. Keep in mind that a supercharger does have it's limitations how my many rpms (not engine rpms, but supercharger rpms) it can spin. If you are reaching the maximum rpms that a supercharger can be spun, it's best to upgrade your supercharger as you do not want to over-spin the supercharger as damage may occur and it will lose it's efficiency.
Old Nov 3, 2005 | 02:11 PM
BADST GS-R's Avatar
BADST GS-R
You wouldn't mess with this, would ya? This street driven (no cage, a/c, cruise control, sub, amp, etc.) supercharged '95 Formula makes 770 rwhp and 682 rwtq with 22 psi from a Procharger F1. This is my other car.
The videos are a little dark. You'll have to brighten up the video to see it a little better.
Here's some boost for ya. Watch the front end lift.
http://www.flp2win.com/video_library/mitchscar4.mpg
Getting tuned with F.A.S.T. by my good friend, Dan Bills of Finish Line Performance.
http://www.flp2win.com/video_library/mitchscar3.mpg
Nothing like pegging the boost gauge.
Old Nov 3, 2005 | 02:19 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Let's keep this relevant to the Integra, please. Thank you.
And I'd like to go on record briefly:
* Aside from the horror story about Moss Motors being less than stellar with regard to servicing and supporting the JRSC line, there aren't any drastic fundamental flaws with the idea of using a positive-displacement Roots or Eaton-type supercharger on a B-series motor.
* That said, the centrifugal superchargers (Vortech being a good example) have had rather poor results with the B-series. They add significant power on the top end, but do little to help torque off the line. Conversely, they work beautifully on small-block V8s, as they aid high-rpm power (where OHV motors tend to get a little wheezy.)
