HID's
Originally Posted by iownzadc2
hey schmoo, since you didn't do a HID Projector Retrofit, how did you get the HID bulbs to fit in the Halogen Projectors? Aren't the HID Base differen't from the Halogen Projector Base?
Originally Posted by Däs Schmoo
That is the problem I think you will run into. With aftermarket HID's, they make the bases on them to fit into a particular socket. With your kit, you will probably be forced to retrofit the HID projectors in order for the base to fit correctly.
what did you do?
Like I said, the aftermarket kit is made with a halogen base. So, I bought the 9006 kit and the bulb fit like a stock halogen bulb into the stock halogen projectors. The only difference is that there is a ballast between the bulb and the harness.
sorry now i'm a little confused, do you know where i can buy one?
Anyways, check out Xenith Xenons in the sponsors forum.
A HID kit? I thought you already had a HID kit. :thinking:
yea i got one..but i'm not sure if it will fit my stock halogen socket.
There are two different ways of getting HIDs that are being posted in this thread. Some people took the lights off of other cars such as the IS 300, they modified the integra head light assembly so that the whole projector assembly for the IS can fit into the integra head light..
Schmoo has a kit where the HID bulb fits directly into the stock integra headlight assembly and just needs to mount a balast (the box that holds all the electronics for the HID system) for each light somewhere in the engine bay.
