Redline
Old Sep 20, 2005 | 11:04 AM
Zak's Avatar
Zak
zak tha mak
Default Redline
The other day i was driving along in my 2000 ls with 70k on it. I was cruising in third at about 5krmp's or so and when i went to shift into fourth i accidentally threw in back into second. Wham, needle winds up at about 7.5krpms, well into the redline. I punched the clutch as soon as it happened, couldent have been in the red for more than a second or two, and i was just wondering how this affects the engine. It runs no different than ran before but i'm just curious how bad it hurts the engine to be in the red
sorry for such a long post, trying to get in all the details
Old Sep 20, 2005 | 11:23 AM
toplineauto's Avatar
toplineauto
makes the engine work too hard, but good business for your mechanic when you blow a head gasket
Old Sep 20, 2005 | 01:38 PM
KaBlookie's Avatar
KaBlookie
4-doors ROCK
a second or two is a LONG time for the engine to be revving at 7500rpm in an LS...since you're saying it seems to be running like normal, all you probably did was knock a couple hundred miles off the life of the motor and burn a lot of gas. Just be careful never to do that again
Old Sep 20, 2005 | 01:40 PM
chewie's Avatar
chewie
you could possibly bent some valves
Old Sep 20, 2005 | 01:54 PM
hakjai's Avatar
hakjai
very common on bmw's since the tranny moves a little on hard turns, its called a "moneyshift" or mis-shift. Worst case scenerio you get bent valves.
Old Sep 20, 2005 | 01:58 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Not by over-revving alone.
Besides, you'd immediately notice the lack of power and terrible idle lope of a dropped valve or a valve that doesnt seat properly.
You did the right thing by de-clutching as soon as possible. If the clutch engagement on the mis-shift was fairly gentle, you're fine. You may have taken 1500 miles or so off of the clutch's life, but that's small potatoes.
Just don't do it again.
Old Sep 20, 2005 | 02:11 PM
Patman015's Avatar
Patman015
Gold Member
red is there for a reason and you should never be in the red.
red is bad.
Old Sep 20, 2005 | 02:22 PM
Zak's Avatar
Zak
zak tha mak
Yeah engine is still running fine with no difference in power or anything.The clutch engagement on the mis-shift felt about as gentle as you would expect for such high rpm's.
I know its kinda off topic, but since were talking about clutch's...
I still got the factory clutch on there,70k, it's working fine but i can notice a little more play in it than it used to have, do yall think it may be time for a replacement?
Old Sep 20, 2005 | 02:56 PM
TheOtherDave™
Apathy Kills
My factory clutch lasted until 97K, so unless the clutch engagement is very early and the shift effort is high, I wouldn't worry about it for another 15K miles or more.
I think one bloke 'round here had his factory clutch last until nearly 125K. :shocked:
Old Sep 20, 2005 | 03:08 PM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
LMFAO yall people feed these people too much shit, "Could be bad"...reving that high isn't bad.. dont worry about it, long as you have no oil leak or white smoke..dont cry over split milk.
