Redline
Old Sep 20, 2005 | 08:18 PM
hakjai's Avatar
hakjai
Originally Posted by IntegraType-R
LMFAO yall people feed these people too much shit, "Could be bad"...reving that high isn't bad.. dont worry about it, long as you have no oil leak or white smoke..dont cry over split milk.
Hes talking about a mis-shift, not revving too high.
Old Sep 21, 2005 | 09:49 AM
Zak's Avatar
Zak
zak tha mak
yeah it was just a mis-shift, but whats the difference, I mean wouldent reving it to high still affect the engine the same way a mis-shift would?
Old Sep 21, 2005 | 02:37 PM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
Mis-shifting involves usually when your racing, and your goin to shift into 4th, but u slam it into 2nd, no hell no is it good for the tranny, nor is reving to 9 k in a ls motor.. but reving to around the mid to high 7 range isn't that bad nor is it as bad as it seems, if you do it, i suggest you pull over, check your oil level, your oil pan for any leaks specially around your half shaft and check for white smoke, if you see nor have any other problems your fine, people rev that high all the time, i've had millions of people tell me that My type-r motor can't handle 9300k revs.. it does every, single day..and has been doing it for over 2 months now with no problems, shit i burn less oil now then i did 3 months ago...btw run fully syn oil in that car if u plan on racing it..i've just decided to change my oil every 3-4 months, and ignore the mileage...
Old Sep 21, 2005 | 02:50 PM
Swisher's Avatar
Swisher
I would have to agree with integratype-r, id say if your needle was still on your rpm guage you shouldnt have a problem. I had a friend do the same thing, except the needle went way off the guage(8000+), and he had no problem in his MX-6
Old Sep 21, 2005 | 09:24 PM
aboobybobpleez's Avatar
aboobybobpleez
Certified Rice-Rocket
went to 8.2K on my chipped ecu/stock top end on accident a while ago when i had my ls...pulled the engine last night but havent taken the head off
Old Sep 22, 2005 | 10:22 AM
Zak's Avatar
Zak
zak tha mak
excellent, i checked my oil and oil pan, nothing abnormal, no white smoke and no difference in performance, i had dino oil in my car when it happened but i have since changed to synthetic
my worst experience was when i buried the tach needel at 9k in my old protege
Old Sep 22, 2005 | 10:25 AM
1turbodc2's Avatar
1turbodc2
got boost?
agreed no worries u should be fine!
Old Sep 22, 2005 | 10:39 AM
Zak's Avatar
Zak
zak tha mak
Thanks for reassuring me
i appericiate all the info
Old Sep 22, 2005 | 04:21 PM
Patman015's Avatar
Patman015
Gold Member
you car will live a short and strainful life h:
Old Sep 22, 2005 | 07:21 PM
hakjai's Avatar
hakjai
if you're really worried you can do a compression test
