Guess the new mod
Originally Posted by shady visions
That's exactly what I thought.
A friend of mine always told me he could put his car in neutral and hear his turbo boost. I always told him there wasn't any need for it to boost as he wasn't moving or shifting.
Originally Posted by Shmoo
Sounds like there is no problem with a turbo running a lightweight flywheel, so I went ahead and ordered my 9lb prolite flywheel with ACT HDSS clutch.
Sweet!! :thumbup:
I got mine at Prostreetonline.com. They have all ACT stuff at 10% off. Where did you order your's at?
Originally Posted by Hondaman
Sweet!! :thumbup:
Ebay. $604 shipped for both.
I would think that if the engine is going through the powerband faster with a lightweight flywheel, it would spool faster. I don't see why you need inertia to build boost when it is only built by exhaust gas that is dependent on RPM and load.
Originally Posted by TeHJuSTiN
With less inertia, there is less load.
h:
Originally Posted by GSSR
jsut out of curiousity if u are getting a turbo next summer why the light flywheel? i though u don't want a lightened flywheel if u go turbo( correct me if i am wrong just tryin to get this cleared up)
As to the point where some of you were saying you can't build boost in neutral... Some cars are built that way so a bearing isn't spun while needlessly reving in neutral. Also, do you hold your gas peddle to the floor in neutral for longer than one second?
