set up 4 boost¿?¿?
Old Apr 18, 2005 | 03:28 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by integra333
cool should i get a turbo then do the ls/vtec converson or is it not worth it¿
will it ever beat a turbo grs or am i asking too much
I personally wouldn't do the LS/VTEC conversion. It adds too many variables and will add less reliability unless you strengthen the bottom end a good amount.
If a GSR and LS were running the same setup and boost level, the GSR would win. But the LS has lower compression, so the boost can be bumped up and even a T3/T4 on an LS would beat my Greddy kit on my GSR.
Old Apr 18, 2005 | 04:06 PM
integra333's Avatar
integra333
what all would i have to do to my block when i rebuild it to set it up 4 boost?
Old Apr 18, 2005 | 04:08 PM
Provocateur
On permanent hiatus
So how much boost are planning on running and is 13 seconds your goal time?
Old Apr 18, 2005 | 04:31 PM
integra333's Avatar
integra333
i dont no how much boost to run, mabey any where from 7 to 12 psi. and yes 13 seconds is my goal
Old Apr 18, 2005 | 05:30 PM
kfar09's Avatar
kfar09
dude, do a search. all of these questions have been asked before. and if all you want is a 13 sec car that is great at daily driving, do the greddy kit like schmoo and I did. pretty safe for the engine and doesn't completely drain your wallet. dont forget you will need a stronger clutch when you put any kind of forced induction (turbo, supercharger, nitrous) on a car. but to reiterate, please use the search.
Old Apr 18, 2005 | 06:32 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I swear I posted this for you before: http://www.c-speedracing.com/howto/motorbuild/build.php
Pretty much the same thing for your motor.
Old Apr 18, 2005 | 07:48 PM
integra333's Avatar
integra333
well i did the search and yes u did post that 4 me. i have looked at kits and seen some for around 3k thats what i was expecting thanks for the help guys :goodjob:
Old Apr 20, 2005 | 04:28 PM
integra333's Avatar
integra333
also what is the difference in turbos for example a T5 compared to T25 and is that the size of the snail¿ or does it have to do with some thing else?
Old Apr 20, 2005 | 04:53 PM
integra333's Avatar
integra333
well i found a rev hard kit for $3100 its a stage 2 kit that has a t/4 t-05 and says a 7 psi sping. is that the max psi that i ca boost or is that what it requires to lift it. also it says +125hp/220trq. will i have to re sleave my bolck or just do wut it says in the link
Old Apr 20, 2005 | 06:00 PM
westcoaststyle
Don't buy anything yet. Read a lot and ask a lot of questions. Those hp/tq ratings are the MAX they think they can get out of the kit and they do not bother telling you how much internal work you need to do nor do they tell you that you will need a nice engine management system (EMS) to run it properly. When it says 7 psi, that means that the wastegate spring that comes with that kit is rated at 7 psi. You will be able to boost a good deal more than that with a manual or electronic boost controller. If you're going to boost more than 10 or 12 psi, then I'd definitely rebuild the motor and sleeve it.
