set up 4 boost¿?¿?
Old Apr 20, 2005 | 08:51 PM
integra333's Avatar
integra333
oh ok that helps alot! how do i know if the turbo requires EMS or not?
Old Apr 20, 2005 | 09:22 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
You should get an EMS with any turbo setup because the stock ECU doesn't have maps for boost nor does it allow tuning of any kind to make the most power with your setup. You can bandaid the ECU with a piggyback but a standalone ECU like AEM or Hondata will get you much better results much safer.
Old Apr 21, 2005 | 05:31 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Exactly! We make a great team.
Old Apr 21, 2005 | 02:52 PM
integra333's Avatar
integra333
cool ill have to look into that
Old Apr 21, 2005 | 04:32 PM
integra333's Avatar
integra333
sorry 4 all the questions but the people that make the kits dont have that much detail about them. thats why i rather talk to people like u guys who no wut they r talikin about.
but how do they size turbos¿ is it the high the # like t88 the bigger the turbo or wut. i just need some helo to pick the right turbo that will get me into the low 12s or possiby lower.
Old Apr 21, 2005 | 05:04 PM
dubcac's Avatar
dubcac
I
I personally wouldn't do the LS/VTEC conversion. It adds too many variables and will add less reliability unless you strengthen the bottom end a good amount.
If he kept the stock redline, nothing would change as far as reliability goes. It's people that try to spin stock LS blocks to 8k and beyond that end up with problems...rod bolt stretch.
Old Apr 21, 2005 | 08:40 PM
Provocateur
On permanent hiatus
I was assuming that he was going to be upping the redline since there is little gain to a ls vtec conversion without doing that. But yeah, you are definitely right about that. Boosted or not, taking a stock LS block to GSR rev limits is just stupid unless you have done some sufficient reinforcement down there.
